Hier habe ich damals eine Liste mit den AM-Variablen gefunden.
http://groups.google.com/group/autom...4072e67caa245a
Automower G2 Variablen
76 Average calculating number [0-9]
77 Added cutting power
87 Different between left & right [pulses]
311 Long average blade motor currency [??]
312 1 if average calculating is ready
403 Pulses from left motor (inc. if forward)
404 Pulses from left motor (inc. if forward)
409 Power right
410 Power left
413 Length left motor (inc. if forward) [pulses]
415 Left wheel direction: 1=forward
416 1 if right wheel will go forward
417 1 if forward right wheel
418 1 if left wheel rotate forward
419 Length past wire [pulses]
424 Loop sensor (front&rear) A0
425 Loop sensor A1
426 Loop sensor N7
427 Loop sensor F9
441 Loop Quality signal (max 500)
442 Loop sensor average F9
458 Loop sensor Average (A0)
475 Front loop sensor A0
476 Rear loop sensor A0
491 Current [mA]
492 Charging time [min]
495 Charging battery amount [mAh]
496 Charging amount left when starting search [mAh]
497 Statuscode
556 Cutting speed [time/puls]
557 Blade motor currency consumption [??]
563 Battery temp. [°C]
564 Time since charging [min]
565 Latest temp. (when charging) [°C]
566 Time to next temp. measure [Sec]
569 Charging number [1-10]
579 Reference wheel speed
592 X angle [??]
599 Up side down [??]
624 Blade motor status
637 Return fast
644 1 if more then 30 pulses outside wire (A0)
645 Time mower inside wire (A0) max 100 [ms]
653 Return run without wire
654 Return fast complex
655 Return fast platanos
656 Return wheel
669 Missing puls signal (0 if no error)
4748 Collision sensor[A/D]
4749 Lift sensors [A/D]
4750 Blade motor current [A/D]
4751 Current left [??]
4752 Current right [??]
4812 Stop button [A/D]
7419 Length past wire [cm]
9407 Speed right
9408 Speed left
12000 Used battery amount [mAh]
12010 Blade motor speed [rpm]
12020 Battery voltage [mV]
12030 Battery voltage current compensated [mV]
Das Prüfen kann man auch am AM machen.
Im Werkzeug-Menue, Aktuelle Daten, Eigene.
Dort kann man vier Adressen eigeben und sich deren Daten anzeigen lassen.
Ich habe das mal mit meinen eigenen Erkenntnissen in Excel zusammen gestellt. (da ist ein VB-Makro zum umrechnen in HEX dabei)
Ich habe mal Fotos vom Einbau des Funkmoduls in den AutoMOwer gemacht.
Auf dem ersten Bild ist dar Transmitter in gut zu sehen.
Das zweite Bild zeigt wie ich das Modul von unten an die Haube geklebt habe. Für die Antenne habe ich ein 2mm Loch in die Haube gebohrt und vor dem ankleben da durchgesteckt. Das Kabel, Rest einer alten Telefonschnur geht nach unten zum Diaganschluss.
Auf dem dritten ist der aus einem ATX-Netzteil hergestellte Stecker zu sehen.
Externes Bild anzeigen Externes Bild anzeigen Externes Bild anzeigen
Das Programm für den PocketPC habe ich nochmal gründlich überarbeitet nach dem ich festellen musste, das sich mein Protokoll ab und an verklemmt hat.
Auf dem Screenshot sind zwei Mähfarten zu sehen.
- Die Blaue linie zeigt die Messwerte der Akkuladung.
Gut zu sehen ist wie der Wert auf 2200mAh nach abschluss der der Ladung gesetzt wird.
Grün kompensierte Akkuspannung.
Blaugrün die gemessene Akkuspannung.
Rot ist die Akkutemperatur.
Schwarz der Lade/EntladeStrom.
