Sooo nun bin ich wieder erwacht :-P
Hier mal mein aktueller Quellcode. Ich mache mit großer Sicherheit irgendwas ganz gravierendes falsch...
Code:#define F_CPU 16000000
#define RC5_HALF_BIT_TIME 8 // 8 * 111µs = 888µs
#define RC5_SEND_ON PORTD |= (1<<PD1)
#define RC5_SEND_OFF PORTD &= ~(1<<PD1)
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdbool.h>
void rc5_send_command(uint16_t command);
void rc5_send_one(void);
void rc5_send_zero(void);
void delay_880(void);
volatile static uint8_t modulation, rc5_half_bit_cnt, rc5_state;
uint16_t rc5_byte = 0x00;
int main(void)
DDRB |= (1<<PB7);
DDRD |= (1<<PD1);
TCCR0A = (1<<WGM01); // CTC
TCCR0B = (1<<CS01); // 8 ( ca. 111µs @ 8 MHz )
TCCR1B = (1<<CS10); // 1 ( ca. 36 kHz @ 8 MHz )
TCCR1B |= (1<<WGM12); // CTC
TIMSK0 = (1<<OCIE0A); // OutputCompare0A
TIMSK1 = (1<<OCIE1A); // OutputCompare1A
OCR0A = (0x6E);
OCR1A = (0x00DD);
sei();
while(1)
rc5_send_command(0b11000000001100);
/* send a 14 bit command to the IR - Receiver */
uint16_t send_byte = command;
for (uint16_t x = 0 ; x < 14 ; x++)
if (send_byte & 0x8000)
rc5_send_one();
else
rc5_send_zero();
send_byte <<= 0x0001;
/* send a logical one to the Receiver ( 1 --> 0 ) */
rc5_state &= ~(0x40);
delay_880();
rc5_state |= (0x40);
delay_880();
/* send a logical zero to the Receiver ( 0 --> 1 ) */
rc5_state |= (0x40); // led on
delay_880();
rc5_state &= ~(0x40); // led off
delay_880();
while(1)
if ((rc5_state & 0x01) == 0x01)
rc5_half_bit_cnt = 0x00;
rc5_state = 0x00;
break;
/* called every 111 µs */
ISR(TIMER0_COMPA_vect)
rc5_half_bit_cnt++;
if (rc5_half_bit_cnt >= RC5_HALF_BIT_TIME)
rc5_state |= 0x01;
/* called every 0,0278 ms */
ISR(TIMER1_COMPA_vect)
if ((rc5_state & 0x40) == 0x40)
RC5_SEND_ON;
else
RC5_SEND_OFF;
