so binde ich den if satz ein:
Code:#include "RP6ControlLib.h"
#include "RP6I2CmasterTWI.h"
#include "RP6Control_I2CMasterLib.h"
#define SRF_ADR 0xE2
#define SRF_ADRS1 0xE4
#define SRF_ADRS2 0xE6
void changeSRFAddr(uint8_t old_addr, uint8_t new_addr)
I2CTWI_transmit2Bytes(old_addr, 0, 0xA0);
I2CTWI_transmit2Bytes(old_addr, 0, 0xAA);
I2CTWI_transmit2Bytes(old_addr, 0, 0xA5);
I2CTWI_transmit2Bytes(old_addr, 0, new_addr);
#define MEASURE_US_LOW 0
#define MEASURE_US_HIGH 1
uint16_t distance;
void I2C_requestedDataReady(uint8_t dataRequestID)
uint8_t messageBuf[8];
static uint8_t dist_tmp;
switch(dataRequestID)
case MEASURE_US_HIGH:
I2CTWI_getReceivedData(messageBuf, 2);
dist_tmp = (messageBuf[0]);
I2CTWI_transmitByte(SRF_ADR, 3);
I2CTWI_requestDataFromDevice(SRF_ADR, MEASURE_US_LOW, 1);
break;
case MEASURE_US_LOW:
distance = messageBuf[0] + (dist_tmp << 8);
writeStringLCD("Distance: ");
writeIntegerLCD(distance, DEC);
writeStringLCD(" cm | ");
writeCharLCD('\n');
setCursorPosLCD(0,0);
break;
void I2C_transmissionError(uint8_t errorState)
writeString_P("\nI2C ERROR --> TWI STATE IS: 0x");
writeInteger(errorState, HEX);
writeChar('\n');
void task_SRF(void)
static uint8_t measureInProgress = false;
if(!measureInProgress)
if(TWI_operation == I2CTWI_NO_OPERATION)
I2CTWI_transmit2Bytes(SRF_ADR, 0, 81);
measureInProgress = true;
setStopwatch1(0);
else if(getStopwatch1() > 70)
I2CTWI_transmitByte(SRF_ADR, 2);
I2CTWI_requestDataFromDevice(SRF_ADR, MEASURE_US_HIGH, 1);
setStopwatch1(0);
I2CTWI_requestDataFromDevice(SRF_ADRS1, MEASURE_US_HIGH, 1);
setStopwatch1(0);
int main(void)
initRP6Control();
initLCD();
I2CTWI_initMaster(100);
I2CTWI_setRequestedDataReadyHandler(I2C_requestedDataReady);
I2CTWI_setTransmissionErrorHandler(I2C_transmissionError);
setLEDs(0b111111);
mSleep(500);
setLEDs(0b000000);
startStopwatch1();
while(true)
task_SRF();
task_I2CTWI();
if(bumper_left || bumper_right)
moveAtSpeed(0,0);
rotate(50, LEFT, 90, true);
moveAtSpeed(80,80);
setLEDs(0b010000);
startStopwatch1();
return 0;
