Zitat:
The \c <avr/sfr_defs.h> file is included by all of the \c <avr/ioXXXX.h>
files, which use macros defined here to make the special function register
definitions look like C variables or simple constants, depending on the
<tt>_SFR_ASM_COMPAT</tt> define. Some examples from \c <avr/iocanxx.h> to
show how to define such macros:
\code
#define PORTA _SFR_IO8(0x02)
#define EEAR _SFR_IO16(0x21)
#define UDR0 _SFR_MEM8(0xC6)
#define TCNT3 _SFR_MEM16(0x94)
#define CANIDT _SFR_MEM32(0xF0)
\endcode
If \c _SFR_ASM_COMPAT is not defined, C programs can use names like
<tt>PORTA</tt> directly in C expressions (also on the left side of
assignment operators) and GCC will do the right thing (use short I/O
instructions if possible). The \c __SFR_OFFSET definition is not used in
any way in this case.
Define \c _SFR_ASM_COMPAT as 1 to make these names work as simple constants
(addresses of the I/O registers). This is necessary when included in
preprocessed assembler (*.S) source files, so it is done automatically if
\c __ASSEMBLER__ is defined. By default, all addresses are defined as if
they were memory addresses (used in \c lds/sts instructions). To use these
addresses in \c in/out instructions, you must subtract 0x20 from them.
For more backwards compatibility, insert the following at the start of your
old assembler source file:
\code
#define __SFR_OFFSET 0
\endcode
Und es funktioniert sogar :-D
