jetzt läuft das sendeprogramm vom rc5-code super.
ist ziemlich kurz und ist mit asm-code gemischt :
$regfile = "m32def.dat"
$framesize = 32
$swstack = 32
$hwstack = 64
$crystal = 8000000
Config Timer1 = Timer , Prescale = 1 , Compare A = Toggle , Clear Timer = 1
Declare Sub Rc5out()
Dim Adre As Byte
Dim Command As Byte
Dim Togglebit As Byte
Dim Z As Byte
Enable Interrupts
Compare1a = 111
For Z = 1 To 5
Adre = 20 + Z
Togglebit = 0
Command = 50 + Z
Call Rc5out()
Waitms 500
Next
End
Sub Rc5out()
!Call Bit_lo
' 2x hi
!Call Bit_hi
!Call Bit_hi
' toglebit
lds r17,{togglebit}
sbrs r17,0
!call bit_lo
sbrc r17,0
!call bit_hi
' 5x adresse
ldi r18,5
Wgloop1:
lds r17,{adre}
sbrs r17,4
!call bit_lo
sbrc r17,4
!call bit_hi
lsl r17
sts {adre},r17
dec r18
brne wgloop1
' 6x command
ldi r18,6
Wgloop2:
lds r17,{command}
sbrs r17,5
!call bit_lo
sbrc r17,5
!call bit_hi
lsl r17
sts {command},r17
dec r18
brne wgloop2
!Call Ende_rc5
Bit_hi:
Config Timer1 = Timer , Prescale = 1 , Compare A = Clear , Clear Timer = 1
Waitus 889
Waitus 889
ret
Bit_lo:
Waitus 889
Waitus 889
ret
Ende_rc5:
Waitms 50
End Sub
