Hi there,
oh good... but have any problems with your program, its not working?
I use port 7 and 8 for sda and scl, i have change it in your programm and the print function on the starter board is deleted.. Hmm where the malfuncion?
thanx
Simple Programm
'**************** I/O PORTS ****************'
define sda port[7]
define scl port[8]
'**************** A/D PORTS ****************'
'**************** D/A PORTS ****************'
'**************** VARIABLES ****************'
define control_flags byte[1]
define i2c_nack bit[1]
define i2c_last bit[2]
define i2c_nack_count byte[2]
define i2c_byte byte[3]
define i2c_out_bit bit[24]
define i2c_in_bit bit[17]
define i2c_loop byte[4]
define servo_number byte[5]
define servo_position byte[6]
'**************** CONSTANTS ****************'
define sd20_i2c_address 194
'****************** SETUP ******************'
'***************** PROGRAM *****************'
#start
servo_number = 1
if (servo_number = 0) or (servo_number > 20) then goto start
servo_position = 200
gosub sd20_servo_driver
goto start
....and the rest of your program...
