Hallo habe jezt dem uhr laufen auf nem lcd.
aber wie schreibe ich ein routiner sum einstellen fon dieser uhr.
also datum und seit, mit 2 oder 4 taster.
Code:$regfile = "m8def.dat" $crystal = 8000000 $baud = 9600 Config Lcdpin = Pin , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7 , E = Portb.3 , Rs = Portb.2 Config Lcd = 20 * 4 Config Sda = Portc.4 Config Scl = Portc.5 Cls $lib "mcsbyte.lbx" ' for smaller code $lib "ds1307rtc.lib" ' modified lib 'address of ds1307 Const Ds1307w = &HD0 ' Addresses of Ds1307 clock Const Ds1307r = &HD1 Config Clock = User ' this will dim the bytes automatic 'dim other needed variables Dim Weekday As Byte Locate 1 , 1 Lcd "DS1307" Waitms 100 ' assigning the time will call the SetTime routine Time$ = "23:58:59" ' to watch the day changing value Date$ = "11-13-02" ' 13 november 2002 Do Cls Locate 1 , 1 Lcd "Datum: " ; Date$ ; Locate 2 , 1 Lcd "Tijd: " ; Time$ Waitms 500 Loop End 'called from ds1307clock.lib Getdatetime: I2cstart ' Generate start code I2cwbyte Ds1307w ' send address I2cwbyte 0 ' start address in 1307 I2cstart ' Generate start code I2cwbyte Ds1307r ' send address I2crbyte _sec , Ack I2crbyte _min , Ack ' MINUTES I2crbyte _hour , Ack ' Hours I2crbyte Weekday , Ack ' Day of Week I2crbyte _day , Ack ' Day of Month I2crbyte _month , Ack ' Month of Year I2crbyte _year , Nack ' Year I2cstop _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour) _day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year) Return Setdate: _day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year) I2cstart ' Generate start code I2cwbyte Ds1307w ' send address I2cwbyte 4 ' starting address in 1307 I2cwbyte _day ' Send Data to SECONDS I2cwbyte _month ' MINUTES I2cwbyte _year ' Hours I2cstop Return Settime: _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour) I2cstart ' Generate start code I2cwbyte Ds1307w ' send address I2cwbyte 0 ' starting address in 1307 I2cwbyte _sec ' Send Data to SECONDS I2cwbyte _min ' MINUTES I2cwbyte _hour ' Hours I2cstop Return
Zitieren
