Update,
GPIO-Routine für Arduino Mega testweise optional ersetzbar durch low-level Register bit read/write:
Code://-------------------------------------------- int32_t test_GPIO_AVR() { // 6,000,000 GPIO bit r/w volatile static bool w=false, r; uint32_t y; for (y=0; y<2000000; y++) { bitWrite(PORTB, PB5, w); w=!w; r = bitRead(PINB, PB7); bitWrite(PORTB, PB6, w&!r); // optional: bitWrite(PORTB, PB6, w&r); } return 1; // debug }Anm.:Code:6a 41569 GPIO digitalRead/Write 6b 4528 GPIO register bitRead/Write
direct port manipulation compiles to 1 or 2 instructions, calling digitalRead is dozens.
One issue to be aware of is interrupts - some of the native direct-port manipulation code will not be
interrupt-safe, where as digitalRead/digitalWrite/pinMode() are carefully coded to work when used
both in an ISR and the main program.
Update 2:
Habe jetzt auch die Routine für optional 32bit fp_op (float) neu geschrieben, die dadurch jetzt auch erhebliche Laufzeitunterschiede zu 64bit double auf allen ARM-Cores erkennen lässt!
Zitieren
