Ich möchte meine Roboter (Arduino Uno, Pololu Dual Motor Driver Shield VNH5019) mit einem kablegebundenem XBox 360 Controller steuern.
Mein Arduino Code:
Mein Processing Code:Code:#include <DualVNH5019MotorShield.h> #include <SoftwareSerial.h> char val; int x = 150; int c = -150; int i = 350; int o = -350; int p = 0; int n = 250; int m = -250; DualVNH5019MotorShield md; void setup() { md.init(); Serial.begin(115200); } void loop() { { if (Serial.available()) { val = Serial.read(); Serial.print(val); } else if (Serial.available()) { val = Serial.read(); Serial.print(val); } } // anfang motor steuerung 50% if (val == 'W') { md.setM1Speed(x); md.setM2Speed(x); } if (val == '0') { md.setM1Speed(p); md.setM2Speed(p); } if (val == 'S') { md.setM1Speed(c); md.setM2Speed(c); } if (val == 'A') { md.setM1Speed(x); md.setM2Speed(c); } if (val == 'D') { md.setM1Speed(c); md.setM2Speed(x); } }
Mein Ziel ist es, die Geschwindigkeit der Motoren möglichst genau mit dem XBox Controller zu steuern.Code:import processing.serial.*; Serial port; int val; color currentcolor; RectButton rect1, rect2, rect3, rect4, rect5; boolean locked = false; void setup() { size(600, 600); color baseColor = color(102, 102, 102); currentcolor = baseColor; port = new Serial(this, "/dev/ttyACM0", 115200); // Define and create rectangle button #1 int x = 150; int y = 250; int size = 80; color buttoncolor = color(153, 153, 153); color highlight = color(102, 102, 102); rect1 = new RectButton(x, y, size, buttoncolor, highlight); // Define and create rectangle button #2 x = 250; y = 250; size = 80; buttoncolor = color(153, 102, 102); highlight = color(102, 102, 102); rect2 = new RectButton(x, y, size, buttoncolor, highlight); // Define and create rectangle button #3 x = 250; y = 350; size = 80; buttoncolor = color(153, 153, 153); highlight = color(102, 102, 102); rect3 = new RectButton(x, y, size, buttoncolor, highlight); // Define and create rectangle button #4 x = 250; y = 150; size = 80; buttoncolor = color(153, 153, 153); highlight = color(102, 102, 102); rect4 = new RectButton(x, y, size, buttoncolor, highlight); // Define and create rectangle button #5 x = 350; y = 250; size = 80; buttoncolor = color(153, 153, 153);
Danke für jede Hilfe
TCHD
Zitieren
