ich sehe da ein Problem im ARDUINO-Code.
Der hängt sich weg, auch wenn man zwischen Senden und Empfangen eine Sekunde Pause einlegt.
Demnach läuft kein Puffer über, aber irgendetwas ist.
Meine aktuellen Codes:
MEGA:
// Wire Slave Receiver
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
#define REGSIZE 240
byte rspeicher[REGSIZE];
byte wspeicher[REGSIZE];
byte puffer[32];
byte Register=1;
byte rdblock=0;
byte wrblock=0;
byte pos=0;
byte fertig=0;
void setup() {
Wire.begin(4); // join I2C bus with address #8
Wire.onReceive(receiveEvent); // register event
// Wire.onReceive(receiveEventRoh); // register event
Wire.onRequest(requestEvent); // register event
Serial.begin(57600); // start serial for output
/* for(byte i=0;i<REGSIZE;i++){
wspeicher[i]=i;
Serial.println();
Serial.println("Starte I2C-Test");
void loop() {
byte i=0;
delay(100);
if (fertig !=0){
fertig=0;
for (i=0;i<REGSIZE;i++){
wspeicher[i]=rspeicher[i];
Serial.print(rspeicher[i]);
Serial.print (" ");
Serial.println();
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
rdblock = Wire.read();
if (rdblock<=7){
pos=0;
while (0 < Wire.available()) {
if (pos<30){
rspeicher[rdblock*30+pos] = Wire.read();
pos++;
if (rdblock==7){
fertig=1;
}else{
if (rdblock >=10 && rdblock <=17){
wrblock=rdblock-10;
Serial.print("Leseblock: ");
Serial.println(wrblock);
void receiveEventRoh(int howMany) {
byte x=Wire.read();
Serial.print (x);
Serial.print (" ");
Serial.println();
// function that executes whenever data is requested by master
void requestEvent() {
//Wire.write(speicher[Register],1);
memcpy( &puffer[1],&wspeicher[wrblock * 30],30);
puffer[0]=wrblock;
Wire.write(puffer,31);
Raspberry Pi:
// GCC -Wall -pthread -o /var/scripte/i2cmaster01 /var/scripte/i2cmaster01.c -lpigpio -lrt
// /var/scripte/i2cmaster01
//I2C mit pipgio
//peterfido
//V0.0.1
#include <stdio.h>
#include <stdlib.h>
//#include <stdarg.h>
#include <string.h>
//#include <ctype.h>
#include <unistd.h>
#include <signal.h>
#include <pigpio.h>
//#define SDA 3
//#define SCL 5
#define BAUD 100
#define ADDRESS 0x04
#define MSGSIZE 240
#define LOOPS 30
char empfdata[MSGSIZE]; //
char senddata[MSGSIZE];
char commando[32];
int handle=0;
int handles=-1;
unsigned int laenge=0;
void handleSigInt( int parameter );
int res=0;
int dl=0;
if (handles >= 0){
for (dl=0;dl<handles;dl++){
res=i2cClose(dl);
printf("%d geschlossen: %d\n",dl, res);
gpioTerminate();
printf( "\nSIGINT wurde augeloest - Programm wird beendet\n" );
exit( 1 );
void senden() {
int res=0;
int i=0;
char wrblock=0;
for (wrblock=0;wrblock<=7;wrblock++){
handle=i2cOpen(1,ADDRESS,0);
handles ++;
if (handle>=0){
laenge=31;
printf("Oeffnen OK %d\n",handle);
res=0;
memcpy( &commando[1],&senddata[wrblock * 30],laenge);
commando[0]=wrblock;
res=res+i2cWriteDevice(handle,commando,laenge);
usleep(5000);
for(i=0;i<laenge;i++){
printf("%d ",commando[i]);
printf("\n");
if (res==0){
printf("Senden OK\n");
}else{
printf("I2C-Fehler: %d\n", res);
res=i2cClose(handle);
if (res!=0){
printf("Fehler beim schliessen: %d\n", res);
}else{
handles--;
}else{
printf("Fehler beim oeffnen: %d\n", res);
void empfangen() {
int res=0;
int i=0;
char rdblock=0;
for (rdblock=0;rdblock<=7;rdblock++){
handles ++;
if (handle>=0){
laenge=31;
commando[0]=rdblock+10;
res=i2cWriteDevice(handle,commando,1);
if (res==0){
usleep(30000);
res=i2cReadDevice(handle,commando,laenge);
if (res>0){
/* printf("Empfangen:\n");
printf("\n");*/
// memcpy( &commando[1],&empfdata[commando[0] * 30],laenge-1);
for (i=0;i<laenge-1;i++){
empfdata[commando[0]*30+i]=commando[i+1];
}else{
printf("Fehler beim Blockeinlesen: %d\n", res);
}else{
printf("Fehler beim Leseblock schreiben %d\n", rdblock);
res=i2cClose(handle);//+i2cClose(handle1);
if (res!=0){
}else{
handles--;
}else{
for(i=0;i<MSGSIZE;i++){
printf("%d ",empfdata[i]);
int vergleichen()
unsigned int i=0;
int ret=0;
for (i=0;i<MSGSIZE;i++){
if (empfdata[i]!=senddata[i]){
ret=-1;
break;
return ret;
int main(int argc, char **argv)
int i=0;
int dg=0;
/* for(i=0;i<MSGSIZE;i++){
senddata[i]=i;
signal( SIGINT, &handleSigInt );
signal( SIGTERM, &handleSigInt );
if (gpioInitialise() < 0)
printf("Fehler beim Initialisieren von gpio!");
gpioTerminate();
}else{
for(dg=0;dg<LOOPS;dg++)
srand(time(NULL));
senddata[i]=rand() % 255;
senden();
// usleep(100000);
sleep(1);
empfangen();
// usleep(100000);
sleep(1);
if (vergleichen()==0){
printf("Daten OK\n");
}else{
printf("Daten fehlerhaft\n");
gpioTerminate();
return 0;
