Ergebnis 1 bis 10 von 16
Thema: Make All geht nicht
    Ok, den Namen habe ich geändert es geht Trotzdem nicht, das komische ist wenn ich z.B. RP6Control_06_I2CMaster in den Selben Ordner einfüge (mit Makefile, Make_All, Make_Clean) funktioniert es.
    nahe Dresden
    ich habe jetzt das original makefile aus dem beispiel "move_10_fast" genommen, an meine pfade angepasst und das hexfile wurde erzeugt. Vergleiche die änderungen zwischen dem original und meinem file...
    # Hey Emacs, this is a -*- makefile -*-
    # RP6 MAKEFILE FOR WinAVR
    # Based on WinAVR Sample makefile written by Eric B. Weddington,
    # Jörg Wunsch, et al.
    # YOU NEED TO EDIT SOME SMALL THINGS IN THIS FILE IF YOU WANT TO USE
    # IT FOR YOUR OWN PROJECTS!
    # THESE LINES ARE ALL AT THE TOP OF THIS FILE AND MARKED VERY CLEARLY !
    # BETTER DO NOT EDIT ANYTHING ELSE!
    # To compile everything you can simply type "make all" on a command line in
    # this directory or simply use the supplied batch files!
    # To remove all the temporary files the compiler has generated you can use
    # "make clean"
    # See end of this file and "make" user manual for more details!
    # Note: Everything behind a '#' is interpreted as a comment in this file!
    # Target file name (without extension).
    # This is the name of your main C source file! Do NOT append the ".c"!
    # Example: Let's assume your main source file is "RP6Base_MyProgram.c", then
    # you would write: TARGET = RP6Base_MyProgram
    TARGET = RP6Control_10_Move2_fast
    # Specify relative path to RP6 library files here.
    # This is "../../RP6lib" or "../RP6lib" usually.
    RP6_LIB_PATH=../../../RP6Lib
    RP6_LIB_PATH_OTHERS= $(RP6_LIB_PATH)/RP6control $(RP6_LIB_PATH)/RP6common $(RP6_LIB_PATH)/RP6mio $(RP6_LIB_PATH)/RP6servo
    #RP6_LIB_PATH=../../2012_lib_komplett
    #RP6_LIB_PATH_OTHERS= ../../2012_lib_komplett
    # Main Source file is _automatically_ added here:
    SRC = $(TARGET).c
    # DO NOT EDIT THIS!
    # If there is more than one source file, append them here separated by spaces.
    # Usually you have to add the Library files here! (ONLY add c files "*.c" here,
    # NO header files "*.h"!)
    # Don't forget to add relative paths!
    SRC += $(RP6_LIB_PATH)/RP6control/RP6ControlLib.c
    SRC += $(RP6_LIB_PATH)/RP6control/RP6Control_I2CMasterLib.c
    SRC += $(RP6_LIB_PATH)/RP6common/RP6uart.c
    #SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CslaveTWI.c
    SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CmasterTWI.c
    SRC += $(RP6_LIB_PATH)/RP6mio/RP6Control_OrientationLib.c
    # You can also wrap lines by appending a backslash to the end of the line
    # like this:
    #SRC += xyz.c \
    #abc.c \
    #asdf.c
    gruß inka
    ja ist doch klar den im Makefile steht bei dir
    SRC += RP6Control_I2CMasterLib.c
    also sucht er genau in diesem Ordner wo dein Programm steht
    Versuch es mal so
    SRC += $(RP6_LIB_PATH)/Dein Ordner wo die Lib steht/RP6Control_I2CMasterLib.c
    Gruß TrainMen
    Ich habe jetzt das Makefile entsprechend geändert und es Funktioniert. Vielen dank für eure Hilfe. Ich merke immer wieder das es ein langer weg wird das Programmieren zu lernen, aber spaß macht es trotzdem noch Bild  .
  1. Make geht gar nicht mehr
    Von asurer im Forum Asuro
    Letzter Beitrag: 27.07.2014, 17:50
  2. Antworten: 3
    Letzter Beitrag: 23.07.2013, 08:28
  3. RP6: Linux make geht nicht
    Von TedRobby im Forum Robby RP6
    Antworten: 7
    Letzter Beitrag: 12.08.2007, 18:50
  4. make all funktioniert nicht.....
    Von blabla im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 22.06.2007, 08:33
  5. make-tool funktioniert nicht
    Von upaucc im Forum Asuro
    Antworten: 15
    Letzter Beitrag: 27.11.2006, 20:37
