Ergebnis 1 bis 10 von 16
Thema: LCD Display (KS0073) in 4 Bit-Modus initialisieren und ansteuern
    Erfahrener Benutzer Roboter-Spezialist Avatar von schorsch_76
    Kurz vor Neuschwanstein
    Du musst halt das C File zu deinen Source Files dazufügen ... Zeig mal dein Makefile, dann kann man hier helfen ...
    Im Städtedreieck Köln-Bonn-Aachen
    # Automatically-generated file. Do not edit!
    SHELL := cmd.exe
    RM := rm -rf
    USER_OBJS :=
    LIBS :=
    PROJ :=
    O_SRCS :=
    C_SRCS :=
    S_SRCS :=
    S_UPPER_SRCS :=
    OBJ_SRCS :=
    ASM_SRCS :=
    PREPROCESSING_SRCS :=
    OBJS :=
    OBJS_AS_ARGS :=
    C_DEPS :=
    C_DEPS_AS_ARGS :=
    EXECUTABLES :=
    OUTPUT_FILE_PATH :=
    OUTPUT_FILE_PATH_AS_ARGS :=
    AVR_APP_PATH :=$$$AVR_APP_PATH$$$
    QUOTE := "
    ADDITIONAL_DEPENDENCIES:=
    OUTPUT_FILE_DEP:=
    LIB_DEP:=
    # Every subdirectory with source files must be described here
    SUBDIRS :=  \
    ../Bib/
    # Add inputs and outputs from these tool invocations to the build variables
    C_SRCS +=  \
    ../Bib/lcd.c \
    ../BMA020+LCD.c
    PREPROCESSING_SRCS +=
    ASM_SRCS +=
    OBJS +=  \
    Bib/lcd.o \
    BMA020+LCD.o
    OBJS_AS_ARGS +=  \
    Bib/lcd.o \
    BMA020+LCD.o
    C_DEPS +=  \
    Bib/lcd.d \
    BMA020+LCD.d
    C_DEPS_AS_ARGS +=  \
    Bib/lcd.d \
    BMA020+LCD.d
    OUTPUT_FILE_PATH +=BMA020+LCD.elf
    OUTPUT_FILE_PATH_AS_ARGS +=BMA020+LCD.elf
    OUTPUT_FILE_DEP:= ./makedep.mk
    LIB_DEP+=
    # AVR32/GNU C Compiler
    Bib/%.o: ../Bib/%.c
        @echo Building file: $<
        @echo Invoking: AVR/GNU C Compiler : 3.4.2
        $(QUOTE)C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE)  -funsigned-char -funsigned-bitfields -DDEBUG  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega8 -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"   -o "$@" "$<"
        @echo Finished building: $<
    ./%.o: .././%.c
    # AVR32/GNU Preprocessing Assembler
    # AVR32/GNU Assembler
    ifneq ($(MAKECMDGOALS),clean)
    ifneq ($(strip $(C_DEPS)),)
    -include $(C_DEPS)
    endif
    endif
    # All Target
    all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
    $(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP)
        @echo Building target: $@
        @echo Invoking: AVR/GNU Linker : 3.4.2
        $(QUOTE)C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="BMA020+LCD.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mmcu=atmega8
        @echo Finished building target: $@
        "C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature  "BMA020+LCD.elf" "BMA020+LCD.hex"
        "C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "BMA020+LCD.elf" "BMA020+LCD.eep" || exit 0
        "C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "BMA020+LCD.elf" > "BMA020+LCD.lss"
        "C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature  "BMA020+LCD.elf" "BMA020+LCD.srec"
        "C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-size.exe" "BMA020+LCD.elf"
    # Other Targets
    clean:
        -$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES)
        -$(RM) $(C_DEPS_AS_ARGS)
        rm -rf "BMA020+LCD.elf" "BMA020+LCD.a" "BMA020+LCD.hex" "BMA020+LCD.lss" "BMA020+LCD.eep" "BMA020+LCD.map" "BMA020+LCD.srec"
    Auf der Suche nach dem Makefile bin ich selber drüber gestoßen, wie ich die C-Datei einbinden kann. Zumindes funktioniert jetzt das Compilieren ohne Fehlermeldung.
    Werde die Tage das mal auf meine Hardware testen. Wenn es Funktioniert, werde ich mich wieder dem ursprünglichen Problem widmen. Nehmlich ohne Fremdbibliothek das LCD ans laufen kommen.
    Sorry, doppel Post.
    Die Bib. von Feury funktioniert, daher ist die Hardware in Ordnung.
    Nun geht es darum raus zu finden, warum meine Code nicht funktionieren will.
    Nachmal danke für die Hilfestellung mit dem Einbinden der Bib.
  1. EADIP204 (KS0073) Display und ° (Grad) Zeichen
    Von cni im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 08.02.2009, 15:42
  2. LCD-Display; 4Bit-Modus immer möglich?
    Von brutzler im Forum AVR Hardwarethemen
    Letzter Beitrag: 29.03.2008, 11:03
  3. Problem 4-zeiliges Display im 4-bit modus!! gelöst!!
    Von zumgwadrad im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 22.11.2006, 16:24
  4. LCD im 8-Bit Modus ansteuern.
    Von michi73 im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 18.11.2005, 19:22
  5. LCD - initialisieren im 4-Bit Modus
    Von henne im Forum AVR Hardwarethemen
    Letzter Beitrag: 12.03.2005, 00:26
