Ok also hier sind die 3 Datein, die ich zum I2C-beutzen verwende:
TWI_Master.h
 Author:					Manfred Langemann
 mailto:					Manfred.Langemann ät t-online.de
 Begin of project:			04.01.2008
 Latest version generated:	04.01.2008
 Filename:					TWI_Master.h
 Description:    			TWI Master functions include file
#ifndef _TWIM
#define _TWIM
#define TWIM_READ    1
#define TWIM_WRITE   0
uint8_t	TWIM_Init (uint32_t TWI_Bitrate);
uint8_t TWIM_Start (uint8_t address, uint8_t TWIM_Type);
void	TWIM_Stop (void);
uint8_t	TWIM_Write (uint8_t byte);
uint8_t	TWIM_ReadAck (void);
uint8_t	TWIM_ReadNack (void);
#endif
TWI_Master.c
 Filename:					TWI_Master.c
 Master code adapted form Peter Fleury <pfleury@gmx.ch>
 http://jump.to/fleury
 Program Example
int main (void)
	uint8_t		i=0;
	uint8_t		j=0;
	uint8_t		Data[8];
	uint8_t		SlaveAddress = 15;
// Clear any interrupt
	cli ();
// Wait 1 second for POR
	Delay_ms (1000);
// Initiate RS232
	RS232_Init ();
	printf ("Hello world...\n");
// Initiate TWI Master with bitrate of 100000 Hz
	TWIM_Init (100000);
// Endless loop
	while (1)
// Read byte(s) from the slave.
// It is implicitely assumed, that the slave will send
// 8 bytes.
    	if (!TWIM_Start (SlaveAddress, TWIM_READ))
			TWIM_Stop ();
			printf ("Could not start TWI Bus for READ\n");
		else
			for (i=0;i<7;i++)
	        	Data[i] = TWIM_ReadAck ();
        	Data[7] = TWIM_ReadNack ();
			printf ("Reading Byte %d: %d\n", i, Data[i]);
			TWIM_Stop ();
			Delay_ms (1000);
// Write byte(s) to the slave.
// accepts 8 bytes
    	if (!TWIM_Start (SlaveAddress, TWIM_WRITE))
			TWIM_Stop ();
			printf ("Could not start TWI Bus for WRITE\n");
		else
			for (i=0;i<8;i++)
	        	TWIM_Write (j++);
				printf ("Byte %d sent\n", j);
			TWIM_Stop ();
			Delay_ms (1000);
// Do something else
		i++;
	return 0;
#include <stdio.h>
#include <avr/interrupt.h>
#define F_CPU 8000000UL				//auf 8MHz stellen? 1Mhz vllt zu langsam?
									//bei 1Mhz =-3 -> false, bei 8Mhz = 32 -> true!
/*uint8_t TWIM_Init(uint32_t TWI_Bitrate)  //uint8_t TWIM_Init (uint32_t TWI_Bitrate)
** Set TWI bitrate
** If bitrate is too high, then error return
TWBR = ((F_CPU/TWI_Bitrate)-16)/2;
if (TWBR < 11) return FALSE;
return TRUE;
#include "General.h"
#include "TWI_Master.h"
  TWI State codes
// General TWI Master staus codes
#define TWI_START					0x08  // START has been transmitted
#define TWI_REP_START				0x10  // Repeated START has been transmitted
#define TWI_ARB_LOST				0x38  // Arbitration lost
// TWI Master Transmitter staus codes
#define TWI_MTX_ADR_ACK				0x18  // SLA+W has been tramsmitted and ACK received
#define TWI_MTX_ADR_NACK			0x20  // SLA+W has been tramsmitted and NACK received
#define TWI_MTX_DATA_ACK			0x28  // Data byte has been tramsmitted and ACK received
#define TWI_MTX_DATA_NACK			0x30  // Data byte has been tramsmitted and NACK received
// TWI Master Receiver staus codes
#define TWI_MRX_ADR_ACK				0x40  // SLA+R has been tramsmitted and ACK received
#define TWI_MRX_ADR_NACK			0x48  // SLA+R has been tramsmitted and NACK received
#define TWI_MRX_DATA_ACK			0x50  // Data byte has been received and ACK tramsmitted
#define TWI_MRX_DATA_NACK			0x58  // Data byte has been received and NACK tramsmitted
// TWI Slave Transmitter staus codes
#define TWI_STX_ADR_ACK				0xA8  // Own SLA+R has been received; ACK has been returned
#define TWI_STX_ADR_ACK_M_ARB_LOST	0xB0  // Arbitration lost in SLA+R/W as Master; own SLA+R has been received; ACK has been returned
#define TWI_STX_DATA_ACK			0xB8  // Data byte in TWDR has been transmitted; ACK has been received
#define TWI_STX_DATA_NACK			0xC0  // Data byte in TWDR has been transmitted; NOT ACK has been received
#define TWI_STX_DATA_ACK_LAST_BYTE	0xC8  // Last data byte in TWDR has been transmitted (TWEA = “0”); ACK has been received
// TWI Slave Receiver staus codes
#define TWI_SRX_ADR_ACK				0x60  // Own SLA+W has been received ACK has been returned
#define TWI_SRX_ADR_ACK_M_ARB_LOST	0x68  // Arbitration lost in SLA+R/W as Master; own SLA+W has been received; ACK has been returned
#define TWI_SRX_GEN_ACK				0x70  // General call address has been received; ACK has been returned
#define TWI_SRX_GEN_ACK_M_ARB_LOST	0x78  // Arbitration lost in SLA+R/W as Master; General call address has been received; ACK has been returned
#define TWI_SRX_ADR_DATA_ACK		0x80  // Previously addressed with own SLA+W; data has been received; ACK has been returned
#define TWI_SRX_ADR_DATA_NACK		0x88  // Previously addressed with own SLA+W; data has been received; NOT ACK has been returned
#define TWI_SRX_GEN_DATA_ACK		0x90  // Previously addressed with general call; data has been received; ACK has been returned
#define TWI_SRX_GEN_DATA_NACK		0x98  // Previously addressed with general call; data has been received; NOT ACK has been returned
#define TWI_SRX_STOP_RESTART		0xA0  // A STOP condition or repeated START condition has been received while still addressed as Slave
// TWI Miscellaneous status codes
#define TWI_NO_STATE				0xF8  // No relevant state information available; TWINT = “0”
#define TWI_BUS_ERROR				0x00  // Bus error due to an illegal START or STOP condition
 Public Function: TWIM_Init
 Purpose: Initialise the TWI Master Interface
 Input Parameter:
 	- uint16_t	TWI_Bitrate (Hz)
 Return Value: uint8_t
 	- FALSE:	Bitrate too high
 	- TRUE:		Bitrate OK
** Set TWI bitrate
	return TRUE;
 Public Function: TWIM_Start
 Purpose: Start the TWI Master Interface
 Input Parameter:
 	- uint8_t	Device address
 	- uint8_t	Type of required Operation:
				TWIM_READ: Read data from the slave
				TWIM_WRITE: Write data to the slave
  	- TRUE:		OK, TWI Master accessible
 	- FALSE:	Error in starting TWI Master
uint8_t TWIM_Start (uint8_t Address, uint8_t TWIM_Type)
	uint8_t		twst;
** Send START condition
	TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
** Wait until transmission completed
	while (!(TWCR & (1<<TWINT)));
** Check value of TWI Status Register. Mask prescaler bits.
	twst = TWSR & 0xF8;
	if ((twst != TWI_START) && (twst != TWI_REP_START)) return FALSE;
** Send device address
	TWDR = (Address<<1) + TWIM_Type;
	TWCR = (1<<TWINT)|(1<<TWEN);
** Wait until transmission completed and ACK/NACK has been received
	twst = TWSR & 0xF8;
	if ((twst != TWI_MTX_ADR_ACK) && (twst != TWI_MRX_ADR_ACK)) return FALSE;
	return TRUE;
 Public Function: TWIM_Stop
 Purpose: Stop the TWI Master
 Input Parameter: None
 Return Value: None
** Send stop condition
	TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
** Wait until stop condition is executed and bus released
	while (TWCR & (1<<TWINT));
 Public Function: TWIM_Write
 Purpose: Write a byte to the slave
 Input Parameter:
 	- uint8_t	Byte to be sent
  	- TRUE:		OK, Byte sent
 	- FALSE:	Error in byte transmission
	uint8_t   twst;
** Send data to the previously addressed device
	TWDR = byte;
	twst = TWSR & 0xF8;
	if (twst != TWI_MTX_DATA_ACK) return 1;
	return 0;
 Public Function: TWIM_ReadAck
 Purpose: Read a byte from the slave and request next byte
  	- uint8_t	Read byte
	TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWEA);
	return TWDR;
 Purpose: Read the last byte from the slave
  	- uint8_t	Read byte
	while(!(TWCR & (1<<TWINT)));
	return TWDR;
Und die dazugehörige General.h
#ifndef _General
#define _General
#define	TRUE	1
#define	FALSE	0
** Here are some deinitions, used in all programs
#define SYSCLOCK				8000000	// Quarz Frequenz in Hz
#define SET_BIT(PORT, BITNUM)	((PORT) |= (1<<(BITNUM)))
#define CLEAR_BIT(PORT, BITNUM) ((PORT) &= ~(1<<(BITNUM)))
#define TOOGLE_BIT(PORT,BITNUM) ((PORT) ^= (1<<(BITNUM)))
struct BitsOfByte
	uint8_t b0:1;
	uint8_t b1:1;
	uint8_t b2:1;
	uint8_t b3:1;
	uint8_t b4:1;
	uint8_t b5:1;
	uint8_t b6:1;
	uint8_t b7:1;
	} __attribute__((__packed__));
#define SBIT(port,pin) ((*(volatile struct BitsOfByte*)&port).b##pin)
#endif
Technik_Amatuer
