Hallo Patrick,
ich habe mal ein kleines Programm angehängt, was NUR die Texteingabe im WIFI-Terminal und die Ausgabe auf dem LCD zeigt.
 * RP6 ROBOT SYSTEM - RP6 CONTROL M256 Examples
 * Example: WIFI Input Example
 * Author(s): Dirk
 * Description:
 * With this program you may test the text input function of the RobotLoader
 * WIFI terminal. If you enter a test string (max. 16 characters), this string
 * is displayed on line 1 of the LCD.
 * There is a bug in RobotLoader 2.3c: If you enter upper case letters in the
 * WIFI terminal, they are received via WIFI as lower case letters!
 * The Robot does NOT move in this example! You can simply put it on a table
 * next to your PC and you should connect it to the PC via the USB Interface!
 * You should also connect to it via WIFI.
// Includes:
#include "RP6M256Lib.h"      // The RP6 M256 Library.
           // Always needs to be included!
// Variables:
// Reception buffer for the function getInputLine_WIFI():
char receiveBufferWifi[UART_RECEIVE_BUFFER_SIZE_WIFI + 1];
// WIFI receive functions:
 * Get chars of an input line from the WIFI.
 * Returns 0 (false), if the WIFI receive buffer is empty
 * OR a character of the input line has been received.
 * Returns 1, if the whole input line has been received
 * (with a "new line" character at the end).
 * Returns 2, if the WIFI receive buffer overflows.
 * The input line is stored in the receiveBufferWifi array.
uint8_t getInputLine_WIFI(void)
{static uint16_t buffer_pos = 0;
 if(getBufferLength_WIFI()) {
  receiveBufferWifi[buffer_pos] = readChar_WIFI();
  if((receiveBufferWifi[buffer_pos] == '\n')
   || (receiveBufferWifi[buffer_pos] == '\r')) {
   receiveBufferWifi[buffer_pos] = '\0';
   buffer_pos = 0;
   return 1;
  else if(buffer_pos >= UART_RECEIVE_BUFFER_SIZE_WIFI) {
   receiveBufferWifi[UART_RECEIVE_BUFFER_SIZE_WIFI] = '\0';
   buffer_pos = 0;
   return 2;
  buffer_pos++;
 return 0;
 * Get a complete input line from the WIFI.
 * This function waits for a whole input line from the WIFI.
 * The function is blocking until one of the two following
 * conditions occurs:
 * - A "new line" character has been received at the end of
 *   the input line.
 * - The WIFI receive buffer overflows.
void enterString_WIFI(void)
 while(!getInputLine_WIFI());
// Main function - The program starts here:
int main(void)
 initRP6M256();    // Always call this first! The Processor will not work
       // correctly otherwise.
 initLCD(); // Initialize the LC-Display (LCD)
      // Always call this before using the LCD!
 setLEDs(0b0000);
 clearLCD(); // Clear the whole LCD Screen
// Main test program:
 while(true)
  writeString_P_WIFI("\n\n");
  writeString_P_WIFI("\n|============================|");
  writeString_P_WIFI("\n| WIFI: Input a test string  |");
  writeString_P_WIFI("\n|       (max. 16 characters) |\n");
  enterString_WIFI();
  // Show the test string on line 1 of the LCD:
  clearLCD();
  writeStringLCD(receiveBufferWifi);
  mSleep(10000);
// End of main:
 return 0;
Jetzt klarer?
