Ergebnis 1 bis 3 von 3
Thema: Tick-Händler für Zeitaufträge
    Tick-Handler für Zeitaufträge
    ;  2012
    .def LEDS    = r16
    .def SWITCH  = r17
    .def SECONDS = r18
    .def TEMP    = r19
    .def TEMP2   = r20
    .def LEDS    = r17
    .cseg
    .org 0
                              ; all 17 ATMega8515 interrupt vectors
                              ; nr. Source  Interrupt Definition
        rjmp RESET              ;(1)  RESET     External Pin, Power-on Reset,
                              ;             Brown-out Reset and Watchdog Reset
        rjmp RESET              ;(2)  INT0     External Interrupt Request 0
        rjmp RESET              ;(3)  INT1     External Interrupt Request 1
        rjmp RESET               ;(4)  TIMER1     CAPT Timer/Counter1 Capt Event
        rjmp start_new        ;(5)  TIMER1     COMPA Timer/Counter1 Comp Match A
        rjmp RESET              ;(6)  TIMER1     COMPB Timer/Counter1 Comp Match B
        rjmp RESET              ;(7)  TIMER1     OVF Timer/Counter1 Overflow
        rjmp RESET             ;(8)  TIMER0     OVF Timer/Counter0 Overflow
        rjmp RESET              ;(9)  SPI,STC Serial Transfer Complete
        rjmp RESET              ;(10) USART,     RXC USART, Rx Complete
        rjmp RESET              ;(11) USART,     UDRE USART Data Register Empty
        rjmp RESET              ;(12) USART,     TXC USART, Tx Complete
        rjmp RESET              ;(13) ANA_COMP Analog Comparator
        rjmp RESET              ;(14) INT2     External Interrupt Request 2
        rjmp RESET              ;(15) TIMER0     COMP Timer/Counter0 Compare Match
        rjmp RESET                   ;(16) EE_RDY     EEPROM Ready
        rjmp RESET              ;(17) SPM_RDY Store Program memory Ready
    RESET:
            ldi TEMP, $FF              ;configure PORTB (output)
            out DDRB, TEMP
    ;----- here we start new or each time the LED-blinking
    ;      comes to its end:
    start_new:
            ;initialize SW stack (since we do not use RETI we have
            ; to clean up the stack this way
            ldi TEMP, low(RAMEND)
            out SPL, TEMP
            ldi TEMP, high(RAMEND)
            out SPH, TEMP
            ldi LEDS, $FF              ;all LEDS on PORTB off (initial state)
            out PORTB, LEDS
    ;----- now start te timer:
    ; set timer depending on which switch was pressed (timer code in reg SWITCH):
    ; switch 0 ~ 1 sec
    ; switch 1 ~ 2 sec
    ; switch 7 ~ 8 sec
    ; 1 sec ~ 3600*1/(clk/1024)=3600*277.78ns,  3600=$e10
    ; TIMSK:  TOIE1 (OCIE1A) OCIE1B ###### TICIE1 ###### TOIE0  OCIE0
    ; TCCR1A: COM1A1 COM1A0  COM1B1 COM1B0 FOC1A  FOC1B  WGM11  WGM10
    ; TCCR1B: ICNC1  ICES1      –   WGM13  WGM12 (CS12   CS11   CS10) -> clock set!
    ; TIFR:   TOV1  (OCF1A)  OCF1B    –    ICF1     –    TOV0   OCF0
    ; CS12 CS11 CS10 Description
    ;  0    0    0   No clock source (Timer/counter stopped).
    ;  0     0    1   clk I/O/1 (No prescaling)
    ;  0    1    0   clk I/O/8 (From prescaler)
    ;  0    1    1   clk I/O/64 (From prescaler)
    ;  1    0    0   clk I/O/256 (From prescaler)
    ;  1    0    1   clk I/O/1024 (From prescaler)
    ;  1    1    0   External clock source on T1 pin. Clock on falling edge.
    ;  1    1    1   External clock source on T1 pin. Clock on rising edge.
    start_timer1:
            ldi TEMP, 64              ;enable Timer1 Output CompareA Match Interrupt
                                     ;-> set Bit6 (OCIE1A) in TIMSK
            out TIMSK, TEMP
            ldi TEMP, 0
            out TCCR1A, TEMP         ;init of TCCR1A -> normal port operation
            ldi TEMP, 1             ; Prescaler 1!!
            out TCCR1B, TEMP         ;select clk/1 as time base TCCR1B=0000 0001
            ldi TEMP, $4E
            out OCR1AH, TEMP          ;set counter target value 20,001=$4e21
                                     ;in OCR1AH $Xe is provided in register $4E
            ldi TEMP, $21             ;
            out OCR1AL, TEMP         ;OCR1AL = $21             ($4E und $21 ergibt 20000)
            ldi TEMP, 0b01000000     ;RESET OCF1A flag by writing 1 in TIFR bit 6
            out TIFR, TEMP
            sei                      ;enable all interrupts
            ldi TEMP, 0
            out TCNT1H, TEMP         ;start timer with initial value 0 and flash
                                     ;the LEDs until timer reaches the
            out TCNT1L, TEMP         ;compareA match value in OCR1AH/L
    task_0:            ;set led0
        in r20, PORTB
        ldi r20, 0b11111110
        out PORTB, r20
        reti
    Atmel 8515, Taktfrequenz 4Mhz, alle 20.000 clock-zyklen ein IRQ
    Der Timer funktioniert mittlerweile, alle 5ms wird ein Interrupt request generiert. Nun soll durch den Interrupt alles 5ms ein Tick-Handler aufgerufen werden der in SRAM gespeicherte Zeitaufträge von verschiedenen kleinen Tasks (Anzahl 5, aber erstmal unerheblich) durchläuft und denjenigen kleine Task aufruft dessen Zeit abgelaufen ist. Die Zeit der Tasks ist frei wählbar, vielfache von 5ms. Die Liste der Zeitaufträge soll als Array der Länge 10 in SRAM implementiert werden. Je nachdem von welchem Task die Wartezeit abgelaufen ist, wird der ein Unterprogrammaufruf (icall) zu dem jeweiligen Task gemacht.
    Ich bin Anfänger in der Assembler-Programmierung und wühle mich seit Tagen durch diverse Tutorials und ich habe keine Ahnung wie ich die Liste der Zeitaufträge erstellen soll und wie ich den Tickhandler der in diese Liste( in SRAM) durchlaufen soll umsetzen kann.
    Vielleicht kann mir ja jemand helfen?
    Geändert von PicNick (02.02.2012 um 09:49 Uhr)
    Kann geclosed werden, es läuft. Die Hilfsbereitschaft hielt sich ja stark in Grenzen
    Keep cool, so schnell geht das nicht.
    Ich mach das so (sprachunabhängig erstma)
    Eine Table von n Entries
    Jeder Table-Entry beinhaltet:
    Byte Flag 0 = inaktiv 1=aktiv 3=call
    Word Counter wieviel Ticks kann auch eine byte sein, wenn das reicht
    Word Vector Icall-Label
    (addit. parameter) die müssen aber nicht sein
    Einen Entry zu erstellen/aktivieren:
    durch die Entries durchsteppen
    wenn flag = 0, dann:
    Counter anzahl Ticks setzen
    Vector Sprungadresse setzen
    Flag auf 1
    Tick-ISR:
    wenn flag = 1, dann:
    Counter - 1
    Wenn Counter == 0 , Flag = 3 (callable)
    next entry
    Hauptschleife, jedesmal (kann man optimieren) durch die Entries durchsteppen
    Wenn Flag = 3 :
    Flag = 0 (deaktivieren)
    ICALL Vector
    next Entry
    Die Trennung ISR / Hauptschleife, damit die aufgerufene Funktion nicht in der ISR läuft.
    Im Detail noch u.a. davon abhängig, ob "erledigte" Entries automatsch reaktiviert werden sollen
    mfg robert
  1. Geigerzähler-Tick nachbilden
    Von NanoBot im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 11.04.2011, 13:33
  2. Händler für qfix
    Von robots4-ever im Forum Allgemeines zum Thema Roboter / Modellbau
    Antworten: 7
    Letzter Beitrag: 07.03.2011, 19:00
  3. Händler für Mechanikteile
    Von deltarobot im Forum Mechanik
    Antworten: 10
    Letzter Beitrag: 24.01.2011, 22:17
  4. Zahnrad Händler
    Von Superhirn im Forum Mechanik
    Antworten: 9
    Letzter Beitrag: 15.09.2007, 08:44
  5. Atmel 24C256 Händler
    Von CityJumper im Forum Controller- und Roboterboards von Conrad.de
    Antworten: 10
    Letzter Beitrag: 06.04.2004, 20:24
