Ergebnis 1 bis 10 von 18
Thema: RP6 -- Ein Motor rückwärts?
    Aachen ---- NRW
    hm.... der Compiler mekert das viele Variablen undeclared sind. Geht es auch so: moveAtSpeed3(speed_links, speed_rechts, dir_links, dir_rechts); ???
    8
    uint16_t distance, distance_left, distanceright;
    Hier fehlt der Unterstrich in distanceright.
    Bringt moveAtSpeed3() einen Vorteil? Es gibt doch nur vier Kombinationen.
    // Richtung: 0 = Vorwärts, 1 = Rückwärts
    moveAtSpeed3(uint8_t desired_speed_left, uint8_t desired_speed_right, uint8_t dir_left, uint8_t dir_right)
    	moveAtSpeed(desired_speed_left, desired_speed_right);
    	setMotorDir(uint8_t dir_left, uint8_t dir_right); // Kommentar in der Lib beachten!
    Aachen ---- NRW
    das mit setMotorDir ist genau das was ich gesucht hab, aber:
    undefined reference to `setMotorDir'
    8
    Möglicherweise wurde die Funktion rausgeschmissen:
     * Sets the rotation direction of both motors.
     * DO NOT CHANGE THE DIRECTION OF THE MOTORS WHILE THEY
     * ARE RUNNING AT HIGH SPEEDS!!!
     * It will not instantly damage the motors/gears, but they will
     * wear out much faster if you do it at high speeds - better wait
     * until speed has slowed down - and change direction AFTER this.
     * IT IS A BETTER IDEA NOT TO USE THIS FUNCTION AT ALL!
     * Use moveAtSpeed together with task_motionControl instead.
     * YOU CAN NOT USE setMotorPower AND setMotorDir WHEN YOU USE
     * task_motionControl!  This will not work!
     * task_motionControl also ensures that the direction is changed
     * slowly and only after the motors have stopped!
     * Example:
     *          // DO NOT perform these commands directly after each
     *			// other in your programs - this is just a LIST of possible
     *			// combinations:
     *			setMotorDir(FWD,FWD); // Move forwards
     *			setMotorDir(BWD,FWD); // Rotate right
     *			setMotorDir(FWD,BWD); // Rotate left
     *			setMotorDir(BWD,BWD); // Move backwards
    void setMotorDir(uint8_t left_dir, uint8_t right_dir)
    	mleft_dir = left_dir;
    	mright_dir = right_dir;
    	mleft_des_dir = left_dir;
    	mright_des_dir = right_dir;
    	if(left_dir)
    		PORTC |= DIR_L;
    	else
    		PORTC &= ~DIR_L;
    	if(right_dir)
    		PORTC |= DIR_R;
    	else
    		PORTC &= ~DIR_R;
    Aachen ---- NRW
    Der Compiler meckert:
    PC.c:24: error: 'DIR_R' undeclared (first use in this function)
    PC.c:20: error: 'DIR_L' undeclared (first use in this function)
    PC.c:18: error: 'mright_des_dir' undeclared (first use in this function)
    PC.c:17: error: 'mleft_des_dir' undeclared (first use in this function)
    PC.c:16: error: 'mright_dir' undeclared (first use in this function)
    PC.c:15: error: 'mleft_dir' undeclared (first use in this function)
    ich benutze die M32.
    Geändert von AsuroPhilip (16.10.2011 um 10:55 Uhr)
    8
    Irgendwie klemmt's heute extrem. Bindest du die Library ein?
    #include "RP6RobotBaseLib.h"
    In task_motionControl() wird bei Stillstand die Richtung ausgewählt:
    				if(!TCCR1A) // Is the PWM module turned off?
    				{			// Yes, change direction and restore old speed:
    					setMotorDir(mleft_des_dir,mright_des_dir);
    					mleft_des_speed = mleft_des_speed_tmp;
    					mright_des_speed = mright_des_speed_tmp;
    					left_i = 0;
    					right_i = 0;
    8
    "ich benutze die M32." Aua
    Aachen ---- NRW
    Ich habe folgende eingebunden:
    #include "RP6ControlLib.h"
    #include "RP6ControlServoLib.h"
    #include "RP6uart.h"
    #include "RP6I2CmasterTWI.h"
    #include "RP6Control_I2CMasterLib.h"
  1. Rechter Motor dreht nur rückwärts
    Von cele93 im Forum Asuro
    Antworten: 104
    Letzter Beitrag: 03.02.2015, 17:04
  2. Ein Motor dreht nur Vorwärts nicht Rückwärts
    Von Hohenloher im Forum Asuro
    Antworten: 12
    Letzter Beitrag: 11.03.2010, 17:23
  3. linker Motor dreht nur rückwärts
    Von icebreaker im Forum Asuro
    Antworten: 59
    Letzter Beitrag: 30.10.2009, 18:18
  4. rechter Motor dreht nur rückwärts!
    Von Munzi im Forum Asuro
    Antworten: 15
    Letzter Beitrag: 07.02.2009, 11:12
  5. Motor rückwärts drehen
    Von Impi im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 14.02.2006, 17:34
