Der hat keinen Jumper. Das ist der, der über USB angesteuert wird. Hier kann man keinen Jumper setzen. Trotzdem danke der Antwort.
Ich habe mal Atmel kontaktiert...Großartige Hilfe:
Dear Customer,
Thank you for contacting Atmel Technical Support.
Red led blinking in AVRISPmkII indicates "Short circuit on target". This is mentioned in AVR studio 5 help --> view help --> AVRISPmkII User Guide --> Hardware description --> Status LED. Hence please check the hardware connections.
To solve the short circuit problem, Please refer to "Trouble shooting: Point 5: AVRISPmkII reports short-circuit on the target" in the Troubleshooting Guide in the AVRISPmkII User Guide.
Also, Try Manually Upgrading the firmware for AVRISPmkII. The procedure is given in AVR studio 5 help --> View help --> AVRISPmkII User Guide --> Troubleshooting --> Manual Firmware Upgrade.
Hope this helps. If the issue still persists, Please get back to us with the following details:
>> AVR Studio version you're using,
>> Target device you're using with description of hardware connections
>> Was the Firmware Upgrade successful, when you tried to upgrade it?
>> Send us the snapshots of the error messages got when you try to communicate with the tool in AVR studio.
Best Regards,
Ineyaa N
Atmel Technical Support Team
Zitieren
