Stimmt, guter Tipp mit den Stopwatches...
Hier ma ein Auszug von der RP6Config.h Datei:
Mache ich da was falsch, oder warum dreht der nicht 90°?Code:/** * Defines a Factor for the rotation error. * As you may have read in the Manual, the rotation is unprecise * because of wheel/track slippery. This Factor allows you to * make it roughly precise. * The Problem is: You need to use different rotation factor * for different surfaces, as the Robot behaves different on * different surfaces (e.g. carpet vs. wooden floor). * * You need to do some experiments with this until you get * good results. Let the Robot rotate by 90°, 180° and 360° * and change the rotation factor depending on if it works * good or not. * * If you want to make it really precise, you will have to * use a Mouse sensor, electronic compass or gyroscope. */ #define ROTATION_FACTOR 950
Crystal Eye
Zitieren
