Hi all,
Hier zu eurer Verfügung ein Progrämmchen, mit dem ein AVR Befehle wie ein Modem "at irgendwas" annehmen kann. Die Eingabezeile wird in bis zu acht Worte zu 16 Zeichen zerlegt, die man dann untersuchen und darauf Unterprogramme starten kann.
Ich brauchte das, weil ich mehrere Controller über Bluetooth via meinem Android-Telefon erreichen wollte.
Gruss
snafu
Code:'receiving input from serial interface, test for leading "at" string and 'interprete various commands to be executed in subroutines $crystal = 20000000 $regfile = "m168def.dat" $baud = 38400 Config Portc.4 = Output Weiss_0 Alias Portc.4 Config Portc.5 = Output Weiss_1 Alias Portc.5 Config Portd = Output Config Lcdbus = 4 Config Lcd = 20 * 2 'configure lcd screen Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , E = Portd.3 , Rs = Portd.2 Rem with the config lcdpin statement you can override the compiler settings 'all neccessary for interrupt input of serial chars Dim Ser_rx_char As String * 1 Dim Ser_rx_char_byte As Byte Dim Serialinput As String * 100 'int routine is collecting input string in this variable Dim New_input_string As String * 100 'if complete string received it will be saved here Dim Parse_string As String * 100 'parser gets this string Dim New_input_string_received As Bit Dim Input_zaehl As Byte Dim String_len As Byte 'variablen für den parser Dim Parser_string_len As Byte Dim Parser_split_pointer As Byte Dim Parse_wd(8) As String * 16 Dim Parse_wd_counter As Byte 'hardware UART is used Config Serialin = Buffered , Size = 10 'PD0 = TXO, PD1 = RXI '10 Byte input buffer Enable Interrupts 'neccessary because UART fires interrupt if new char received '-------------- INIT ----------------------------------------------------------- Cls Upperline '---"01234567890123456789" Lcd "PARSER" Lowerline Lcd "0.32" Cursor Off Noblink Serialinput = "" 'Inputpuffer reset New_input_string = "" 'input string reset reset New_input_string_received = 0 'flag reset Print "--- RESET ---" '-------------- MAIN ----------------------------------------------------------- Do '-------------- fetch waiting chars If Ischarwaiting() = 1 Then 'poll buffer of UART routine Gosub Serial_zeichen_abholen End If '-------------- test for new input string If New_input_string_received = 1 Then 'complete string was received New_input_string_received = 0 'flag reset Parse_string = New_input_string 'prepare string for parser Print Gosub Parse_input_string 'analyze words in received string End If Loop '-------------- end MAIN ------------------------------------------------------- '-------------- subroutines ---------------------------------------------------- Parse_input_string: '-------------- parse input string For Parse_wd_counter = 1 To 8 'strip leading blanks While Left(parse_string , 1) = " " Parser_string_len = Len(parse_string) Parser_string_len = Parser_string_len - 1 Parse_string = Right(parse_string , Parser_string_len) Wend 'find first blank char Parser_split_pointer = Instr(parse_string , " ") 'look for first blank character If Parser_split_pointer > 0 Then '= 0 if no blank found Parser_split_pointer = Parser_split_pointer - 1 End If 'isolate first parse word If Parser_split_pointer > 16 Then 'avoid to set Parse_wd(n) with strings longer than 16 chars Parser_split_pointer = 16 End If Parse_wd(parse_wd_counter) = Mid(parse_string , 1 , Parser_split_pointer) 'reduce parse string to remaining chars which are still due to parse If Parser_split_pointer > 0 Then ' Parser_split_pointer = Parser_split_pointer + 1 Parser_string_len = Len(parse_string) Parser_string_len = Parser_string_len - Parser_split_pointer Parse_string = Right(parse_string , Parser_string_len) Else 'last command word in parse string found Parse_string = "" End If 'Print "[" ; Parse_wd(parse_wd_counter) ; "]"; Next '-------------- interprete commands with arguments Select Case Parse_wd(1) Case "at" : Gosub Attention Case Else Print "missing at string, received: [" ; Parse_wd(1) ; "]" Print "send [at command argument]" End Select Return '-------------- commands Attention: Select Case Parse_wd(2) Case "led0" : Gosub Led0 Case "led1" : Gosub Led1 Case Else Print "missing or wrong command, received: [" ; Parse_wd(2) ; "]" Print "send [led0 | led1]" End Select Return Led0: Select Case Parse_wd(3) Case "on" Weiss_0 = 1 Print "ok" Case "off" Weiss_0 = 0 Print "ok" Case Else Print "missing or wrong argument, received: [" ; Parse_wd(3) ; "]" Print "send [on | off]" End Select Return Led1: Select Case Parse_wd(3) Case "on" Weiss_1 = 1 print "ok" Case "off" Weiss_1 = 0 Print "ok" Case Else : Print "missing or wrong argument, received: [" ; Parse_wd(3) ; "]" End Select Return '-------------- receive serial characters -------------------------------------- ' collect received chars and assemble them to input string Serial_zeichen_abholen: If Ischarwaiting() = 1 Then Ser_rx_char = Inkey() Ser_rx_char_byte = Asc(ser_rx_char) String_len = Len(serialinput) Select Case Ser_rx_char_byte Case 13 'return chra was recognized New_input_string = Serialinput 'copy string for main routine New_input_string_received = 1 'set flag that new string is ready Serialinput = "" 'reset all for new string Ser_rx_char = "" Case 127 'backspace - char If String_len > 0 Then Print Chr(8) ; " " ; Chr(8); 'android recognizes no chr(127), therefore i use backspace, writing blank, backspace again String_len = String_len - 1 If String_len = 0 Then 'because "left" returns even with (string,0) one char Serialinput = "" Else Serialinput = Left(serialinput , String_len) End If End If Case Is < 32 'drop all ather control chars Ser_rx_char = "" Case Is > 127 Ser_rx_char = "" Case Else 'valid input char If String_len < 100 Then 'room left in input string? Serialinput = Serialinput + Ser_rx_char 'append received char Print Ser_rx_char ; 'and echo via serial Else 'abort if 99 chars without enter received New_input_string = Serialinput 'then string will be closed without enter Serialinput = "" New_input_string_received = 1 Ser_rx_char = "" End If End Select End If Return
Zitieren
