Sorry für die Ergänzung: es muss noch der Controller definiert werden und der MCU-Takt. Ein Ausschnitt aus (m)einer lauffähigen lcdxy.h für ein 2x24-Display, einem KS0073 und einen 4-Bit-Anschluss (4-bittig, das ist mein Standard) lautet daher so:
Änderungsbeispiel: Hast Du aus welchen Gründen auch immer, den LCD-Data1pin auf PORT D2, dann heisst diese Liste so:Code:/** * @name Definitions for MCU Clock Frequency * Adapt the MCU clock frequency in Hz to your target. */ #define XTAL 20000000 /**< clock frequency in Hz, used to calculate delay timer */ /** * @name Definition for LCD controller type * Use 0 for HD44780 controller, change to 1 for displays with KS0073 controller. */ #define LCD_CONTROLLER_KS0073 1 /**< Use 0 for HD44780 controller, 1 for KS0073 controller */ /** * @name Definitions for Display Size * Change these definitions to adapt setting to your display */ #define LCD_LINES 2 /**< number of visible lines of the display */ #define LCD_DISP_LENGTH 24 /**< visibles characters per line of the display */ //#define LCD_LINE_LENGTH 0x40 /**< internal line length of the display */ #define LCD_START_LINE1 0x00 /**< DDRAM address of first char of line 1 */ #define LCD_START_LINE2 0x40 /**< DDRAM address of first char of line 2 */ #define LCD_START_LINE3 0x14 /**< DDRAM address of first char of line 3 */ #define LCD_START_LINE4 0x54 /**< DDRAM address of first char of line 4 */ #define LCD_WRAP_LINES 0 /**< 0: no wrap, 1: wrap at end of visibile line */ #define LCD_IO_MODE 1 /**< 0: memory mapped mode, 1: IO port mode */ #if LCD_IO_MODE /** * @name Definitions for 4-bit IO mode * Change LCD_PORT if you want to use a different port for the LCD pins. * * The four LCD data lines and the three control lines RS, RW, E can be on the * same port or on different ports. * Change LCD_RS_PORT, LCD_RW_PORT, LCD_E_PORT if you want the control lines on * different ports. * * Normally the four data lines should be mapped to bit 0..3 on one port, but it * is possible to connect these data lines in different order or even on different * ports by adapting the LCD_DATAx_PORT and LCD_DATAx_PIN definitions. * */ #define LCD_PORT PORTB /**< port for the LCD lines */ #define LCD_DATA0_PORT LCD_PORT /**< port for 4bit data bit 0 */ #define LCD_DATA1_PORT LCD_PORT /**< port for 4bit data bit 1 */ #define LCD_DATA2_PORT LCD_PORT /**< port for 4bit data bit 2 */ #define LCD_DATA3_PORT LCD_PORT /**< port for 4bit data bit 3 */ #define LCD_DATA0_PIN 4 /**< pin for 4bit data bit 0 */ #define LCD_DATA1_PIN 3 /**< pin for 4bit data bit 1 */ #define LCD_DATA2_PIN 2 /**< pin for 4bit data bit 2 */ #define LCD_DATA3_PIN 1 /**< pin for 4bit data bit 3 */ #define LCD_RS_PORT PORTC /**< port for RS line */ #define LCD_RS_PIN 2 /**< pin for RS line */ #define LCD_RW_PORT PORTC /**< port for RW line */ #define LCD_RW_PIN 1 /**< pin for RW line */ #define LCD_E_PORT PORTC /**< port for Enable line */ #define LCD_E_PIN 0 /**< pin for Enable line */
Viel ErfolgCode:#define LCD_PORT PORTB /**< port for the LCD lines */ #define LCD_DATA0_PORT LCD_PORT /**< port for 4bit data bit 0 */ #define LCD_DATA1_PORT PORTD /**< port for 4bit data bit 1 */ #define LCD_DATA2_PORT LCD_PORT /**< port for 4bit data bit 2 */ #define LCD_DATA3_PORT LCD_PORT /**< port for 4bit data bit 3 */ #define LCD_DATA0_PIN 4 /**< pin for 4bit data bit 0 */ #define LCD_DATA1_PIN 2 /**< pin for 4bit data bit 1 = PD2 !! */ #define LCD_DATA2_PIN 2 /**< pin for 4bit data bit 2 */ #define LCD_DATA3_PIN 1 /**< pin for 4bit data bit 3 */ #define LCD_RS_PORT PORTC /**< port for RS line */ #define LCD_RS_PIN 2 /**< pin for RS line */ #define LCD_RW_PORT PORTC /**< port for RW line */ #define LCD_RW_PIN 1 /**< pin for RW line */ #define LCD_E_PORT PORTC /**< port for Enable line */ #define LCD_E_PIN 0 /**< pin for Enable line */
Zitieren
