Ergebnis 1 bis 10 von 16
Thema: RP6Control M32: Impulslängen-Messgerät
    NRW
    Hallo RP6 Fans,
    manchmal hilft ein Impulslängen- und Frequenzmesser:
     * RP6 ROBOT SYSTEM - RP6 CONTROL M32 TESTS
     * Example: Impulse length measurement with input capture
     * Author(s): Dirk
     * Description:
     * With this program the lengths of positive impulses of an unknown TTL signal
     * connected to the input capture pin (ICP) of the M32 (PD6, I/O pin 8) can be
     * displayed on the LCD.
     * If you uncomment the definition FREQUENCY, the frequency of the unknown TTL
     * signal will be displayed instead of the impulse length.
     * The Robot does NOT move in this example! You can simply put it on a table
     * next to your PC and you should connect it to the PC via the USB Interface!
    // Includes:
    #include "RP6ControlLib.h" 		// The RP6 Control Library.
    								// Always needs to be included!
    // Defines:
    //#define FREQUENCY						// Measure the frequency
    										// (instead of the impulse length)
    // Variables:
    typedef union {
    	uint32_t i32;
    	struct {
    		uint8_t  i8l;					// Low byte
    		uint8_t  i8m;					// Middle byte
    		uint16_t i16h;					// High uint
    } icrcounter_t;
    volatile uint16_t ovfcnt = 0;			// Number of overflows during
    										//  the measurement
    volatile uint32_t timediff;
    uint32_t time;
    double result;
    #define FALLING_EDGE	0				// (or next rising edge)
    #define RISING_EDGE		1
    volatile uint8_t edgeflag;
    char buffer[12];						// Buffer for ASCII conversion
    // Functions:
     * TIMER1 Overflow ISR
     * In this ISR the ICR1 overflows are counted.
    ISR (TIMER1_OVF_vect)
    	++ovfcnt;							// Count the overflows
     * TIMER1 Capture ISR
     * In this ISR the cycles from a rising edge to the falling (or the next
     * rising) edge are calculated.
    ISR (TIMER1_CAPT_vect)
    {static icrcounter_t icrcnt_start;
     icrcounter_t icrcnt_end;
    	if (edgeflag == RISING_EDGE) {		// Rising edge!
    		icrcnt_start.i8l = ICR1L;		// Low byte first
    		icrcnt_start.i8m = ICR1H;		// High byte is buffered
    		ovfcnt = 0;						// Reset overflow counter
    #ifndef FREQUENCY
    		TCCR1B &= ~(1<<ICES1);			// Next trigger: Falling edge
    #endif
    		edgeflag = FALLING_EDGE;
    	else {								// Falling (or next rising) edge!
    		icrcnt_start.i16h = 0;			// Reset upper 16 bits (start value)
    		icrcnt_end.i8l = ICR1L;			// Low byte first
    		icrcnt_end.i8m = ICR1H;			// High byte is buffered
    		// If low ICR1H and waiting overflow interrupt:
    		if ((icrcnt_end.i8m < 128) && (TIFR & (1<<TOV1))) {
    			// Do the job of the waiting timer overflow interrupt:
    			++ovfcnt;
    			TIFR = (1<<TOV1);			// Clear Timer1 overflow interrupt
    		icrcnt_end.i16h = ovfcnt;		// Upper 16 bits (overflow counter)
    		timediff = icrcnt_end.i32 - icrcnt_start.i32;
    #ifndef FREQUENCY
    		TCCR1B |= (1<<ICES1);			// Next trigger: Rising edge
    #endif
    		edgeflag = RISING_EDGE;
    // Main function - The program starts here:
    int main(void)
    	initRP6Control();	// Always call this first! The Processor will not
    						// work correctly otherwise.
    	initLCD();			// Initialize the LC-Display (LCD)
    						// Always call this before using the LCD!
    	// Write some text messages to the LCD:
    	showScreenLCD("################", "################");
    	mSleep(1500);
    	showScreenLCD("<<RP6  Control>>", "<<LC - DISPLAY>>");
    	mSleep(2500);
    	showScreenLCD("Imp. Measurement", "Version 1.00 ICP");
    	mSleep(2500);
    	clearLCD(); // Clear the whole LCD Screen
    	// Clear the four Status LEDs:
    	setLEDs(0b0000);
    	// Initialize the M32 ICP pin (PD6) as input:
    	DDRD &= ~IO_PD6;
    	PORTD |= IO_PD6;					// Pullup on
    	// Initialize the M32 Timer1 input capture function:
     	TCCR1B = (1<<ICES1) | (1<<CS10)	// Trigger: Rising edge, no prescaling
    	 | (1<<ICNC1);						//  and noise canceler
    	TIMSK = (1<<TICIE1) | (1<<TOIE1);	// Activate capture & overflow ISR
    	TIFR = (1<<TOV1) | (1<<ICF1);		// Clear active interrupts
    	while(true)
    		cli();
    		time = timediff;
    		sei();
    		if (time > 0) {
    			ultoa(time, buffer, DEC);	// Convert to ASCII
    			setCursorPosLCD(0, 0);
    			writeStringLCD("CNT ");		// Counter value ( / F_CPU [s])
    			writeStringLCD(buffer);
    			writeStringLCD("    ");
    			setCursorPosLCD(1, 0);
    #ifndef FREQUENCY
    			result = (double) time / F_CPU;
    			writeStringLCD("IMP ");		// Impulse length [s]
    			dtostrf(result, 11, 7, buffer); // Convert to ASCII
    #else
    			result = (double) F_CPU / time;
    			writeStringLCD("FRQ ");		// Frequency [Hz]
    			dtostrf(result, 11, 3, buffer); // Convert to ASCII
    #endif
    	return 0;
     * Additional info
     * Changelog:
     * - v. 1.0 (initial release) 27.02.2010 by Dirk
    Dieses Programm macht die M32 zu einem solchen "Messgerät" mit der Input Capture Funktion.
    Viel Spaß damit
    Gruß Dirk
    Gibt es eigentlich einen besonderen Grund für die englischen Kommentare?
    NRW
    Hallo radbruch,
    Möglichkeiten:
    1. Ich will mein Englisch üben
    2. Ich mache es genau so wie bei den RP6 Beispielen
    3. Ich bin Engländer
    4. Ich liebe die Queen
    5. Ich denke, wer programmiert, sollte Englisch können
    6. Mein Goldfisch heißt Timothy
    7. Ich will nur angeben
    8. Ich bin ein bißchen crazy (Entschuldigung: verrückt)
    9. Mein Französisch ist zu schlecht
    Du kriegst 100 Punkte, wenn du das Richtige herausfindest!
    Lieben Gruß Bild
    Dirk
    Erfahrener Benutzer Begeisterter Techniker Avatar von RobbyMartin
    Leverkusen
    dein französisch ist zu sclecht Bild
    NRW
    Oui, mon cher. \ Bild  /
    Hallo Dirk
    Danke für deine ausführliche Antwort. Den wahren Grund in deiner Auswahl zu finden fällt mir echt schwer, jeder für sich würde für mich schon deine englischen Kommentare begründen. Was ich nun aber nicht nachvollziehen kann:
    Warum schreibst du denn deine Beiträge nicht komplett in englisch?
    Mit ebenfalls liebem Gruß
    NRW
    Hallo mic,
    sorry! Ich hätte vielleicht nicht so flapsig mit deiner Frage umgehen sollen.
    Die wahre Antwort ist:
    Meine Programme für den RP6 schreibe ich im Stil von SlyD, weil er dem RP6 schon ein eigenes Gepräge gibt. Dazu gehört nicht nur die Form, sondern auch die englischen Kommentare (mit Ausnahme der C-Control M12 Bild  . Mir gefällt es, dass man auf einen Blick erkennen kann: Das Prog ist für den RP6.
    Natürlich muss man das nicht so machen, obwohl ich denke, dass die Programmteile, die man hier häufig sieht, ein bißchen Form gut gebrauchen könnten.
    Dann bin ich zu faul, meine Progs vor der Veröffentlichung abzuändern.
    Also: Am besten trifft Nr. 2 zu, aber auch an Nr. 5 ist etwas dran.
    Nr. 7 trifft überhaupt nicht zu, und ich habe auch keinen Goldfisch, aber meine Frau hat mit der Queen zusammen Geburtstag.
    In einem deutschen Forum schreibe ich natürlich auch Deutsch.
    Frage an den Moderator radbruch: Würdest du denken, dass wir Programme hier eher mit deutschen Kommentaren reinstellen sollten? Ich werde das dann gern machen.
    Lieber Gruß (das meine ich so!!)
    Dirk
    Hallo Dirk
    Erstmal danke für deinen zweiten Anlauf. Diese Argumente klingen nun gar nicht mehr flapsig.
    Der RP6 wird in Asien produziert und weltweit verkauft. Deshalb blieb SlyD bei der Entwicklung der Library wohl auch keine andere Wahl als englisch zu kommentieren. Da du unter all den RP6-Benutzern, die sich hier im Forum tummeln, der einzige bist, dessen Programme in den Bereich von SlyDs Meisterleistung kommen, kann ich gut nachvollziehen, dass du dich seiner Gestaltung der Quellcodes anpassen willst.
    Umso überraschter bin ich nun vom Quellcode in diesem Thread:
    https://www.roboternetz.de/phpBB2/viewtopic.php?t=53051
    Auf den ersten Blick eindeutig als typisches RP6-/M32-Programm nach Vorbild der Library erkennbar, fällt der deutsche Kommentar erst auf den zweiten Blick auf. Wirklich super. Ich denke, ich bin nicht der Einzige hier, dem das sehr gefällt. Danke.
    NRW
    Ok, danke!
    Werde bei deutschen Kommentaren bleiben!
    Gruß Dirk
    nahe Dresden
    Hallo Dirk,
    diese schaltung stammt aus dem IR-bake thread:
    bei der schaltung versuche ich nun eine definierte blinkfrequenz einzustellen. Eigentlich dachte ich, es müsste auch auf dem OSZI zu sehen sein in welcher frequenz der blinker den zustand ändert, geht aber irgendwie nicht, ich bekomme nur eine durchgezogene linie angezeigt, die in einem bestimmten rhythmus von einem level zum anderen springt. Ich kann also diese beiden level ablesen, wollte aber eigentlich was anderes...
    Da habe ich mich an dieses programm erinnert...
    habe die zeile "#define FREQUENCY" aktiviert, den code compiliert (keine fehlermeldungen) und in die m32 geladen. Die meldungen beim start kommen wie es im code steht, dann bleibt aber das display leer, egal ob meine schaltung angeschlossen ist oder nicht.
    Anschluss der blinkerschaltung nach dem hier:
    der I/O Pin 8 vom IO-Mxxx landet am Jumperblock J_IO an dem Pin, der mit "8" beschriftet ist.
    Das ist der 2. Pin von links,- oben drüber steht "Rx"
    und eine beliebige masse (habe den GND pin auf der multi I/O auf der Gyro pinnleiste, neben dem XBUS wannenstecker genommen)
    was ist da falsch? Ich weiss nicht, aber sollte das display nicht noch etwas anzeigen bevor gemessen wird?
    danke für Deine zeit...
    gruß inka
