Mithilfe von Dirks Servo Base Bibliothek und dem TV_Remote Bspl habe ich folgendes Programm "geschrieben" :
Code:// written David Smutny // RP6BaseServoLib was written by Dirk // ------------------------------------------------------------------------------------------ #include "RP6BaseServoLib.h" #include "RP6RobotBaseLib.h" #define RC_YOUR_OWN #ifdef RC_YOUR_OWN #define RC5_KEY_LEFT 20 #define RC5_KEY_RIGHT 22 #define RC5_KEY_FORWARDS 18 #define RC5_KEY_BACKWARDS 24 #define RC5_KEY_STOP 32 #define RC5_KEY_CURVE_LEFT 17 #define RC5_KEY_CURVE_RIGHT 19 #define RC5_KEY_CURVE_BACK_LEFT 23 #define RC5_KEY_CURVE_BACK_RIGHT 25 #define RC5_KEY_LEFT_MOTOR_FWD 26 #define RC5_KEY_LEFT_MOTOR_BWD 41 #define RC5_KEY_RIGHT_MOTOR_FWD 42 #define RC5_KEY_RIGHT_MOTOR_BWD 49 #define RC5_KEY_SERVO_L 37 #define RC5_KEY_SERVO_R 36 #endif #define MAX_SPEED_MOVE 200 #define MAX_SPEED_TURN 100 #define MAX_SPEED_CURVE 120 #define MAX_SPEED_CURVE2 40 #define ACCELERATE_CURVE 10 #define ACCELERATE_CURVE2 4 #define DECELERATE_CURVE 4 #define DECELERATE_CURVE2 2 #define MAX_SPEED_1_MOTOR 120 #define ACCELERATE_VALUE 8 #define DECELERATE_VALUE 4 uint8_t max_speed_left; uint8_t max_speed_right; uint8_t acl_left; uint8_t acl_right; uint8_t decl_left; uint8_t decl_right; uint16_t pos = 0; uint8_t servorcan = 1; //rechter Servo uint8_t servolcan = 1; //linker Ser void setDefaultSpeedParameters(void) { max_speed_left = MAX_SPEED_MOVE; max_speed_right = max_speed_left; acl_left = ACCELERATE_VALUE; acl_right = ACCELERATE_VALUE; decl_left = DECELERATE_VALUE; decl_right = DECELERATE_VALUE; uint16_t tmp = (getDesSpeedLeft() + getDesSpeedRight())/2; moveAtSpeed(tmp , tmp); } void receiveRC5Data(RC5data_t rc5data) { writeString_P("Toggle Bit:"); writeChar(rc5data.toggle_bit + '0'); writeString_P(" | Device Address:"); writeInteger(rc5data.device, DEC); writeString_P(" | Key Code:"); writeInteger(rc5data.key_code, DEC); writeChar('\n'); #ifndef DO_NOT_MOVE uint8_t movement_command = false; switch(rc5data.key_code) { case RC5_KEY_LEFT: writeString_P("LEFT\n"); setDefaultSpeedParameters(); max_speed_left = MAX_SPEED_TURN; max_speed_right = max_speed_left; changeDirection(LEFT); setLEDs(0b100000); movement_command = true; break; case RC5_KEY_RIGHT: writeString_P("RIGHT\n"); setDefaultSpeedParameters(); max_speed_left = MAX_SPEED_TURN; max_speed_right = max_speed_left; changeDirection(RIGHT); setLEDs(0b000100); movement_command = true; break; case RC5_KEY_FORWARDS: writeString_P("FORWARDS\n"); setDefaultSpeedParameters(); changeDirection(FWD); setLEDs(0b100100); movement_command = true; break; case RC5_KEY_BACKWARDS: writeString_P("BACKWARDS\n"); setDefaultSpeedParameters(); changeDirection(BWD); setLEDs(0b001001); movement_command = true; break; case RC5_KEY_STOP: writeString_P("STOP\n"); max_speed_left = 0; max_speed_right = max_speed_left; moveAtSpeed(0,0); setLEDs(0b011011); movement_command = true; break; case RC5_KEY_CURVE_LEFT: writeString_P("CURVE LEFT FWD\n"); max_speed_left = MAX_SPEED_CURVE2; max_speed_right = MAX_SPEED_CURVE; acl_left = ACCELERATE_CURVE2; acl_right = ACCELERATE_CURVE; decl_left = DECELERATE_CURVE2; decl_right = DECELERATE_CURVE; changeDirection(FWD); setLEDs(0b110100); movement_command = true; break; case RC5_KEY_CURVE_RIGHT: writeString_P("CURVE RIGHT FWD\n"); max_speed_left = MAX_SPEED_CURVE; max_speed_right = MAX_SPEED_CURVE2; acl_left = ACCELERATE_CURVE; acl_right = ACCELERATE_CURVE2; decl_left = DECELERATE_CURVE; decl_right = DECELERATE_CURVE2; changeDirection(FWD); setLEDs(0b100110); movement_command = true; break; case RC5_KEY_CURVE_BACK_LEFT: writeString_P("CURVE LEFT BWD\n"); max_speed_left = MAX_SPEED_CURVE2; max_speed_right = MAX_SPEED_CURVE; acl_left = ACCELERATE_CURVE2; acl_right = ACCELERATE_CURVE; decl_left = DECELERATE_CURVE2; decl_right = DECELERATE_CURVE; changeDirection(BWD); setLEDs(0b011001); movement_command = true; break; case RC5_KEY_CURVE_BACK_RIGHT: writeString_P("CURVE RIGHT BWD\n"); max_speed_left = MAX_SPEED_CURVE; max_speed_right = MAX_SPEED_CURVE2; acl_left = ACCELERATE_CURVE; acl_right = ACCELERATE_CURVE2; decl_left = DECELERATE_CURVE; decl_right = DECELERATE_CURVE2; changeDirection(BWD); setLEDs(0b001011); movement_command = true; break; case RC5_KEY_LEFT_MOTOR_FWD: writeString_P("MOTOR LEFT FWD\n"); max_speed_left = 0; max_speed_right = MAX_SPEED_1_MOTOR; acl_left = 4; acl_right = 4; decl_left = 4; decl_right = 4; changeDirection(FWD); setLEDs(0b110000); movement_command = true; break; case RC5_KEY_LEFT_MOTOR_BWD: writeString_P("MOTOR LEFT BWD\n"); max_speed_left = 0; max_speed_right = MAX_SPEED_1_MOTOR; acl_left = 4; acl_right = 4; decl_left = 4; decl_right = 4; changeDirection(BWD); setLEDs(0b101000); movement_command = true; break; case RC5_KEY_RIGHT_MOTOR_FWD: writeString_P("MOTOR RIGHT FWD\n"); max_speed_left = MAX_SPEED_1_MOTOR; max_speed_right = 0; acl_left = 4; acl_right = 4; decl_left = 4; decl_right = 4; changeDirection(FWD); setLEDs(0b000110); movement_command = true; break; case RC5_KEY_RIGHT_MOTOR_BWD: writeString_P("MOTOR RIGHT BWD\n"); max_speed_left = MAX_SPEED_1_MOTOR; max_speed_right = 0; acl_left = 4; acl_right = 4; decl_left = 4; decl_right = 4; changeDirection(BWD); setLEDs(0b000101); movement_command = true; break; case RC5_KEY_SERVO_L: writeString_P("Servo nach links\n"); pos -= 10; break; case RC5_KEY_SERVO_R: writeString_P("Servo nach rechts\n"); pos += 10; break; } if(movement_command) { if(getDesSpeedLeft() < max_speed_left) { moveAtSpeed(getDesSpeedLeft()+acl_left, getDesSpeedRight()); if(getDesSpeedLeft() < 10) moveAtSpeed(10, getDesSpeedRight()); } if(getDesSpeedRight() < max_speed_right) { moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()+acl_right); if(getDesSpeedRight() < 10) moveAtSpeed(getDesSpeedLeft(), 10); } setStopwatch4(0); startStopwatch4(); } #endif } void deccelerate(void) { if(getStopwatch4() > 250) { if(getDesSpeedLeft() <= 10) moveAtSpeed(0, getDesSpeedRight()); else moveAtSpeed(getDesSpeedLeft()-decl_left, getDesSpeedRight()); if(getDesSpeedRight() <= 10) moveAtSpeed(getDesSpeedLeft(), 0); else moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()-decl_right); if (getDesSpeedRight() == 0 && getDesSpeedLeft() == 0) stopStopwatch1(); max_speed_left = getDesSpeedLeft(); max_speed_right = getDesSpeedRight(); setLEDs(0b000000); setStopwatch4(0); } if(getDesSpeedLeft() > max_speed_left) { if(getDesSpeedLeft() <= 10) moveAtSpeed(0, getDesSpeedRight()); else moveAtSpeed(getDesSpeedLeft()-decl_left, getDesSpeedRight()); } if(getDesSpeedRight() > max_speed_right) { if(getDesSpeedRight() <= 10) moveAtSpeed(getDesSpeedLeft(), 0); else moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()-decl_right); } } int main(void) { initRobotBase(); setLEDs(0b111111); writeChar('\n'); writeString_P("RP6 controlled by RC5 TV Remote\n"); writeString_P("___________________________\n"); mSleep(500); setLEDs(0b000000); powerON(); IRCOMM_setRC5DataReadyHandler(receiveRC5Data); writeString_P("\n * Turn Left: "); writeInteger(RC5_KEY_LEFT, DEC); writeString_P("\n * Turn Right: "); writeInteger(RC5_KEY_RIGHT, DEC); writeString_P("\n * Move Forwards: "); writeInteger(RC5_KEY_FORWARDS, DEC); writeString_P("\n * Move Backwards: "); writeInteger(RC5_KEY_BACKWARDS, DEC); writeString_P("\n * Stop: "); writeInteger(RC5_KEY_STOP, DEC); writeString_P("\n * Move curve left forwards: "); writeInteger(RC5_KEY_CURVE_LEFT, DEC); writeString_P("\n * Move curve right forwards: "); writeInteger(RC5_KEY_CURVE_RIGHT, DEC); writeString_P("\n * Move curve left backwards: "); writeInteger(RC5_KEY_CURVE_BACK_LEFT, DEC); writeString_P("\n * Move curve right backwards: "); writeInteger(RC5_KEY_CURVE_BACK_RIGHT, DEC); writeString_P("\n * Motor left forwards: "); writeInteger(RC5_KEY_LEFT_MOTOR_FWD, DEC); writeString_P("\n * Motor left backwards: "); writeInteger(RC5_KEY_LEFT_MOTOR_BWD, DEC); writeString_P("\n * Motor right forwards: "); writeInteger(RC5_KEY_RIGHT_MOTOR_FWD, DEC); writeString_P("\n * Motor right backwards: "); writeInteger(RC5_KEY_RIGHT_MOTOR_BWD, DEC); writeString_P("\n * Servo nach rechts: "); writeInteger(RC5_KEY_SERVO_R, DEC); writeString_P("\n * Servo nach links: "); writeInteger(RC5_KEY_SERVO_L, DEC); writeString_P("\n-----------------------\n"); startStopwatch2(); initSERVO(SERVO1); while(true) { servo1_position = pos; deccelerate(); task_RP6System(); } return 0; }Code:Wenn ich nun die entsprechende Taste drücke bewegt sich der servo aber nicht... :-s Kann mir jemand helfen? danke schonmal gruß David
						 Zitieren
Zitieren
