hier ist die compilerausgabe, beim übersetzen des selftest_M32 programms (ich hoffe du meinst das hier):
> "make.exe" all
-------- begin --------
avr-gcc (WinAVR 20080610) 4.3.0
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling: RP6Control_SELFTEST.c
avr-gcc -c -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Control_SELFTEST.lst -I../../RP6Lib -I../../RP6Lib/RP6control -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Control_SELFTEST.o.d RP6Control_SELFTEST.c -o RP6Control_SELFTEST.o
Linking: RP6Control_SELFTEST.elf
avr-gcc -mmcu=atmega32 -I. -gdwarf-2   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=RP6Control_SELFTEST.o -I../../RP6Lib -I../../RP6Lib/RP6control -I../../RP6Lib/RP6common -std=gnu99 -MD -MP -MF .dep/RP6Control_SELFTEST.elf.d RP6Control_SELFTEST.o ../../RP6Lib/RP6control/RP6ControlLib.o ../../RP6Lib/RP6common/RP6uart.o ../../RP6Lib/RP6common/RP6I2CmasterTWI.o --output RP6Control_SELFTEST.elf -Wl,-Map=RP6Control_SELFTEST.map,--cref    -lm
Creating load file for Flash: RP6Control_SELFTEST.hex
avr-objcopy -O ihex -R .eeprom RP6Control_SELFTEST.elf RP6Control_SELFTEST.hex
Creating Extended Listing: RP6Control_SELFTEST.lss
avr-objdump -h -S RP6Control_SELFTEST.elf > RP6Control_SELFTEST.lss
Creating Symbol Table: RP6Control_SELFTEST.sym
avr-nm -n RP6Control_SELFTEST.elf > RP6Control_SELFTEST.sym
Size after:
AVR Memory Usage
Device: atmega32
Program:    7368 bytes (22.5% Full)
(.text + .data + .bootloader)
Data:        203 bytes (9.9% Full)
(.data + .bss + .noinit)
-------- end --------
> Process Exit Code: 0
aber ich glaube du hast mich falsch verstanden. das kompilieren sämtlicher programme funktioniert fehlerfrei, zumindest spuckt der compiler keine fehlermeldung aus.
ich programmiere ja auch schon länger mit dem RP6 und da hab ich bisher auch noch nie probleme mit dem compilieren gehabt.
das komplette hexfile schick ich dir per PM.
mfg andi
