Werbung
Erfahrener Benutzer
Roboter Genie
hiermit kanst du eine word variable als 2 byte "rohdaten" senden:
dim x as word
printbin x
auszug aus der Bascom hilfe:
Syntax
PRINTBIN var [ ; varn]
PRINTBIN #channel, var [; varn]
Remarks
PRINTBIN is equivalent to PRINT CHR(var);
When you use a Long for example, 4 bytes are printed.
Multiple variables may be sent. They must be separated by the ; sign.
The number of bytes to send can be specified by an additional numeric parameter. This is convenient when sending the content of an array.
Printbin ar(1) ; 3 ' will send 3 bytes from array ar().
Printbin ar(1) ; 2 ; ar(2) ; 4 ' will send 2 bytes from array ar() starting at index 1, then 4 bytes from array ar() starting at index 4.
When you use Printbin ar(1) , the whole array will be printed.
When you need to print the content of a big array(array with more then 255 elements) you need to use the CONFIG PRINTBIN option.
gruss bluesmash
- Neue Themen erstellen: Nein
- Themen beantworten: Nein
- Anhänge hochladen: Nein
- Beiträge bearbeiten: Nein
Foren-Regeln
Werbung
