ich versuche Sternthalers Programm zur Asuro Parameterermittlung zum laufen zu bekommen.
Beim Compilieren mit WinAVR / PN kriege ich folgende Fehlermeldungen:
hier sind die ersten warning Codezeilen (Zeilen 601 bis 604):Code:> "make.exe" all set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro_st.lst asuro_st.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro_st.d; \ [ -s asuro_st.d ] || rm -f asuro_st.d set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \ [ -s test.d ] || rm -f test.d -------- begin -------- avr-gcc --version avr-gcc (GCC) 4.2.2 (WinAVR 20071221) Copyright (C) 2007 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o test.c: In function 'get_switch': test.c:602: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:604: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:645: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:648: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:649: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:650: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c: In function 'get_odo': test.c:864: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:865: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:866: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:870: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:881: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:961: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:965: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:976: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:987: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c: In function 'get_go': test.c:1130: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:1132: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c: In function 'get_turn': test.c:1267: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness test.c:1269: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro_st.lst asuro_st.c -o asuro_st.o asuro_st.c: In function 'PrintInt': asuro_st.c:1078: warning: pointer targets in passing argument 1 of 'SerWrite' differ in signedness C:\DOKUME~1\PETERS~1.PN1\LOKALE~1\Temp/cc33U6Im.s: Assembler messages: C:\DOKUME~1\PETERS~1.PN1\LOKALE~1\Temp/cc33U6Im.s:490: Warning: expression dangerous with linker stubs C:\DOKUME~1\PETERS~1.PN1\LOKALE~1\Temp/cc33U6Im.s:491: Warning: expression dangerous with linker stubs avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro_st.o --output test.elf -Wl,-Map=test.map,--cref -lm avr-objcopy -O ihex -R .eeprom test.elf test.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O ihex test.elf test.eep c:\Asuro\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used avr-objdump -h -S test.elf > test.lss Size after: test.elf : section size addr .text 6768 0 .data 158 8388704 .bss 486 8388862 .stab 888 0 .stabstr 95 0 .debug_aranges 64 0 .debug_pubnames 716 0 .debug_info 3553 0 .debug_abbrev 817 0 .debug_line 4400 0 .debug_frame 384 0 .debug_str 1464 0 .debug_loc 940 0 Total 20733 Errors: none -------- end -------- > Process Exit Code: 0 > Time Taken: 00:04
Wie muss die Funktion SerWrite benutzt werden, um nicht diese Warnung zu generieren?Code:/* Dem PC-Programm den Tasten-ADC-Wert mitteilen */ SerWrite ("<", 1); PrintInt (v_taster); SerWrite (">", 1);
Wenn ich das Programm compiliert habe, auf den Asuro geflashed habe und die Windows App Sensoren executiere, kriege ich keine Daten vom Asuro in die WIN App. Kann jemand helfen?
