Hi
Habs nun nachn bischen probieren und nochmal komplett neu schreiben hinbekommen.
Code:define LIGHT as port[16] define BPORT1 as byteport[1] import "...\LIB\SHOW_BINARY.BAS" import "...\LIB\PULLUP1_ENABLE.BAS" define ADC8 ad[8] define SDA as port[9] define SCL as port[10] define EXTPORT as byteport[4] define STATION_IO as byte[3] define REL1 as bit [21] define REL2 as bit [22] define REL3 as bit [23] define REL4 as bit [24] PULLUP1_ENABLE() LIGHT=off LCD.INIT SDA=on SCL=on STATION_IO=OFF #HAUPTSCHLEIFE EXTPORT=STATION_IO LCD.POS 1,1 LCD.PRINT "BINARY: " SHOW_BINARY(BPORT1) '--- D1 - D4 --- if (BPORT1 = 11111110b) then Do Loop Until BPORT1 <> 11111110b if ( REL1 = OFF) then REL1 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL1 = ON) then REL1 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 11111101b) then Do Loop Until BPORT1 <> 11111101b if ( REL2 = OFF) then REL2 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL2 = ON) then REL2 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 11111011b) then Do Loop Until BPORT1 <> 11111011b if ( REL3 = OFF) then REL3 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL3 = ON) then REL3 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 11110111b) then Do Loop Until BPORT1 <> 11110111b if ( REL4 = OFF) then REL4 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL4 = ON) then REL4 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if end if '--- D5 - D8 --- if (BPORT1 = 11101111b) then Do Loop Until BPORT1 <> 11101111b if ( REL1 = OFF) then REL1 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL1 = ON) then REL1 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 11011111b) then Do Loop Until BPORT1 <> 11011111b if ( REL2 = OFF) then REL2 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL2 = ON) then REL2 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 10111111b) then Do Loop Until BPORT1 <> 10111111b if ( REL3 = OFF) then REL3 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL3 = ON) then REL3 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if goto HAUPTSCHLEIFE end if if (BPORT1 = 01111111b) then Do Loop Until BPORT1 <> 01111111b if ( REL4 = OFF) then REL4 = ON EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if if ( REL4 = ON) then REL4 = OFF EXTPORT=STATION_IO goto HAUPTSCHLEIFE end if end if goto HAUPTSCHLEIFE
Zitieren
