Ich bräuchte mal etwas Hilfe bei meinem Code.
Allen verfügbaren Tutorials zum trotz renn ich in grosse Probleme wenn ich mehr als einen Timer einsetzen möchte, und/oder mehr als einen Interrupt habe.
; Lazy Sine wave for the Butterfly
; Lookuptable for a quarter Sine wave
; Portb6 for an LED, right next to GND
; ---  insert GPL here  --- Wiebel, 2007
; timer2 interrupt behaves very badly, first for some time PWM at $(ff)
; then Sine uncorrelated to frequency of Timer2
.include "m169def.inc"
.def temp  = r16
.def pow = r17
.def ACount = r18
.def BCount = r19
.def PCount = r20
.def state= r21
.def speed = r22
.def table = r0   ; Z points here, readout of table
.org 0x0000
        rjmp    main                    ; Reset Handler
.org PCINT0addr                         ; next, button support
        reti
;       rjmp   button
;.org 0x0014
.org OC2addr                ; Interrupt for the adjustable
;.org OVF2addr        ; speed TIMER2
;       reti
        rjmp    timer2_ctc
.org OVF1addr
        reti
;       rjmp    timer1_overflow       ; Timer Overflow Handler
.org OVF0addr
        reti
;       rjmp    timer0_overflow
main:
        clt
        ldi     temp, LOW(RAMEND)     ; Stackpointer
        out     SPL, temp
        ldi     temp, HIGH(RAMEND)
        out     SPH, temp
        ldi     temp, 0               ; initializing I/O Pins
        out     DDRE, temp      ; Input (Joystick right-left)
        ldi     temp, 1<<PORTB6            ; Output LED (also Joy up)
        out     DDRB, temp
;       ldi     temp, 0b00000010      ; TOIE0: Interrupt at Timer Overflow
;       sts     TIMSK0, temp
        ldi     temp, 0b00000010     ; Interupt on compare
        sts     TIMSK2,      temp
;       ldi     temp, 1<<PCIE0  ; next
;       sts     EIMSK, temp
;       ldi    temp, $ff
;       ldi    temp, (1<<PCINT2) | (1<<PCINT3)
;       sts    PCMSK0, temp
;       ldi    temp, 1<<ISC00
;       sts    EICRA, temp
; initializing registers
        clr     ACount                     ; PWM / SINE rate   (L) Counter
        clr     BCount                     ; Adjustable speed  (H) Counter
                                        ; X/Y ??
        clr     state                        ; State machine q1-q2-q3-q4-
        clr     PCount                  ; bookkeeper for table qsin
        clr     pow   ; PWM - duty cycle
        ldi     speed, $ff      ; Adjustable Speed Value
        ldi     temp, 0b00000010|(1<<WGM21) ; divider | CTC mode
        sts     TCCR2a, temp
        ldi     temp,$3f          ; compare value for CTC
        sts     OCR2A, temp
        ldi     temp, (1<<COM1B1) | (1<<WGM11)  ; setting timer1 ...
;       ldi    temp, 0b00100010
        sts     TCCR1A, temp
        ldi     temp, (1<<WGM13) | (1<<WGM12)  | (1<<CS10) ; ... at full speed
;       ldi    temp, 0b00011001
        sts     TCCR1B, temp
        ldi     temp, 0x00      ; setting the top value for counter1
        sts ICR1H, temp   ; for the Sine-Wave PWM
        ldi     temp, 0xff
        sts ICR1L, temp
        ldi ZH, high(qsin<<1)      ; pointing to qsin:
        ldi ZL, low(qsin<<1)        ; quarter Sine lookup table
        ldi     temp, $ff        ; initial PWM Level
        sts     OCR1BL, temp
        ldi     temp, $0
        sts     OCR1BH, temp
;       sbi PORTB, 6         ; futile previous attempts
        sei                    ; activate interupts
loop:   rjmp      loop      ; well nothing here
timer2_ctc:
        inc     ACount    ; loop to delay the actual reading
        cpi     ACount, $3F             ; delay for * interupt events
        brne    out
        clr     ACount
;       cp     BCount, speed                ; second for longer delays (4bit PWM)
;       brlo   bout                     ; or adjustable (via speed)
;       clr    BCount
        inc     PCount                  ; increment the bookkeeping
        lpm
        ldi     pow, $7f          ; ofFset for the full Sinewave
        cpi     state, 0          ; in which quadrant are we ?
        breq    q0
        cpi     state, 1
        breq    q1
        cpi     state, 2
        breq    q2
        cpi     state, 3
        breq    q3
        ldi     state, 0          ; reset the state machine
q0:                         ; 1st quadrant, forward, positive
        add     pow, table   ; add value of table to the Offset
        rjmp    up
q1:                         ; 2nd Q, backward, positive
        add     pow, table
        rjmp    down
q2:                         ; 3rd Q, forward, negative
        sub     pow, table
        rjmp    up
q3:                     ; 4th Q, backward, negative
        sub     pow, table
        rjmp    down
up:                         ; moving Z forward
        inc     ZL
        rjmp    level
down:               ; moving Z backward
        dec     ZL
        rjmp    level
level:          ; setting the actual PWM level
        sts     OCR1BL, pow
        cpi     PCount, $1f             ; have we reached the end of the Table?
        brne    out
        inc     state                   ; go to next quadrant
        clr     PCount      ; reset bookkeeping
        reti
;bout:          ; to make BCount adjustable
;       inc    BCount
out:
        reti
        ;button:                                ; next
        ;reti
        ;       sbis    PINE, PINE3
        ;        ldi    speed, $0
        ;        sbis    PINE, PINE2
        ;        ldi    speed, $0f
        ;       sts    OCR1BL, speed
        ;       reti
qsin:
; .org  FlashEND-(0xFF/2)       ; need more information
; quarter Sine - 127*sin(n/32) - 32 Points -128 points per Sine
.db     0,6,13,19,26,32,38,44,50,56,62,67,73,78,83,87,92,96,100,104,107,111,114,117,119,121,123,124,126,126,127,127
; quarter Sine - 127*sin(pi*n/16) - 16 Points - 64 points per Sine
; .db   0,13,26,39,52,64,75,85,94,103,110,116,121,124,126,127            ; 127*sin(pi*n/16)
; .db     0,6,13,19,26,32,38,44,50,56,62,67,73,78,83,87,92,96,100,104,107,111,114,117,119,121,123,124,126,126,127,127
Also angefangen hab ich mit dem Sinus Lookup der (geteilt durch ACount/BCount) direkt mit Timer1, der auch die PWM steuert, abgeklappert wird. Soweit so gut. Als ich versuchen wollte einen weiteren Interrupt für die Tasten zu implementieren fingen dei Probleme an. Der Timer1
Interrupt kam nicht mehr durch. Dann wollte ich erstmal eine eigene Timerbasis für die Lookuptable machen, um Interrupt events zu sparen (Vorteiler statt ACount/BCount) damit mehr Luft für die Tasten bleibt (später). Timer0 war der völlige Reinfall, beim aktivieren von Timer0 ging überhaupt nichts mehr.
Also versuche ich es gerade mit Timer2 da geht was aber nicht das was es soll.
Timer2 soll über ein Compare Event seinen Interrupt werfen, welcher das Auslesen der Lookuptable voran bringt, soweit die Theorie.
Praktisch geht beim Start meine LED auf 100% an und verweilt in dieser unglücklichen Situation solange Timer2 eben hochzählt (diese zeit kann ich über Vorteiler und ORC2A gut beeinflussen), dann geht er in den Sinus als ob es keinen Timer2 mehr geben würde, was ja eigentlich heißt das Timer1 immernoch weitertriggert.
Ich steh noch sehr am Anfang mit µC daher hab ich sicher irgendwas Grundlegendes mit dem Interruptvektor Verhunzt.
Wenn ein geworfener Interrupt nicht im Vektor steht (also kein reti) wird dann automatisch zum nächsten übergegagnen? Also wenn z.B. ein
INT0 ankommt aber PCINT2 erst im Vektor steht, wird dann PCINT1 ausgeführt?
Ich hab keine Ahnung was ich noch versuchen kann, hab schon alles Mögliche ausprobiert.
Den Code auch nochmal als URL(mit Highlighting)
http://nopaste.gamedev.pl/?id=655[/code]
PS: Sorry für das Crossposting, ich hoffe ihr seht mir das nach. Bild   -> mikrocontroller.net
