Ich versuche auf einem ARM7 Intterupts zu benutzen. Der Timer läuft richtig, nur Interrupts bekomme ich noch nicht... Welche Register hab ich vergessen?
Danke schon einmal!
Code:#include <LPC21xx.H> // olimex LPC-P2129: LEDs on P0.12/P0.13 (active low) #define LED1PIN 12 #define LED2PIN 13 void T0IRQ (void) __irq; unsigned short switcher = 0; int main(void) { //INIT // define LED-Pins as outputs IODIR0 |= 1<<LED1PIN; // set Bits = LEDs off (active low) IOSET0 = 1<<LED1PIN; //Sets peripheral clock = system clock VPBDIV=0x01; //initialise timer 0 T0TCR = 0x0; T0TC = 0x0; T0PR = 0x0; T0PC = 0x0; T0MR0 = 0xFF; //Reset and interrupt on match T0MCR = 0x3; //TELL VIC WHAT TO DO! VICIntSelect = 0x0; //NO FIQs VICIntEnable = 0x4; //TIMER 0 on board //Give the VIC the adress VICVectAddr0=(unsigned long) T0IRQ; //start the timer T0TCR=0x1; while(1){} } void T0IRQ (void) __irq { //TOGGLE LED if(switcher) { IOSET0 = 0<<LED1PIN; switcher = 0; } else { switcher = 1; IOSET0 = 1<<LED1PIN; } //RESET NECCESSARY TIMER VALUES T0IR=0x1; //END ISR VICVectAddr=0xff; }
Zitieren
