Seite 13 von 41 ErsteErste ... 3111213141523 ... LetzteLetzte
Ergebnis 121 bis 130 von 405
Thema: Alternative zu Flashnnn.exe
  1. #121
    @ juelicher
    Dann bekomm ich folgende Fehlermeldung.
    Asuro Flash (Alias Eierlegendewollmilchsau)	 V1.1.5.30 (c) O.O. Müller 2006
    User has admin rights.
    Processor , OS WINXP
    Hello Tom on PAUL, have fun :)
    Session Environment Variables:
    AF_AVRDIR=C:\Programme\Asuro\WinAVR
    AF_PROJECT=Project1
    AF_SOURCE_FILES=
    AF_ASM_SRC_FILES=
    AF_PRGDIR=C:\Programme\Asuro\AsuroFlash
    >Ready.
    AF_PROJECT=Test
    AF_SOURCE_FILES=Test.c
    AF_ASM_SRC_FILES=
    Default make_clean.cmd file created.
    Default makefile created.
    Make clear
    C:\Programme\Asuro\AsuroFlash\Test>C:\Programme\Asuro\WinAVR\utils\bin\make.exe clean
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=C:\Programme\Asuro\asuro_libv271\lib/asuro.lst -IC:\Programme\Asuro\AsuroFlash\include -IC:\Programme\Asuro\asuro_libv271\lib\inc C:\Programme\Asuro\asuro_libv271\lib/asuro.c \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    	[ -s asuro.d ] || rm -f asuro.d
    avr-gcc.exe: C:ProgrammeAsuroasuro_libv271lib/asuro.c: No such file or directory
    avr-gcc.exe: no input files
    -------- begin --------
    rm -f Test.hex
    rm -f Test.eep
    rm -f Test.obj
    rm -f Test.cof
    rm -f Test.elf
    rm -f Test.map
    rm -f Test.obj
    rm -f Test.a90
    rm -f Test.sym
    rm -f Test.lnk
    rm -f Test.lss
    rm -f Test.o asuro.o
    rm -f  Test.lst asuro.lst
    rm -f Test.s asuro.s
    rm -f Test.d asuro.d
    Errors: none
    -------- end --------
    Ready.
    AF_PROJECT=Test
    AF_ASM_SRC_FILES=
    File Test.c saved.
    Default make_all.cmd file created.
    Make
    C:\Programme\Asuro\AsuroFlash\Test>C:\Programme\Asuro\WinAVR\utils\bin\make.exe all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Test.lst -IC:\Programme\Asuro\AsuroFlash\include -IC:\Programme\Asuro\asuro_libv271\lib\inc Test.c \
    	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > Test.d; \
    	[ -s Test.d ] || rm -f Test.d
    avr-gcc --version
    avr-gcc (GCC) 4.2.2 (WinAVR 20071221)
    Copyright (C) 2007 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Test.lst -IC:\Programme\Asuro\AsuroFlash\include -IC:\Programme\Asuro\asuro_libv271\lib\inc Test.c -o Test.o
    Test.c:5: warning: return type of 'main' is not 'int'
    Test.c: In function 'main':
    Test.c:11: warning: 'return' with a value, in function returning void
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=Test.o -IC:\Programme\Asuro\AsuroFlash\include -IC:\Programme\Asuro\asuro_libv271\lib\inc Test.o asuro.o  --output Test.elf -Wl,-Map=Test.map,--cref -IC:\Programme\Asuro\AsuroFlash\lib -LC:\Programme\Asuro\asuro_libv271\lib -lm -lasuro
    avr-gcc: asuro.o: No such file or directory
    make: *** [Test.elf] Error 1
    ExitCode 2
    Ready.
    Tut mir leid das ich euch damit so nerve
    aber ich kann mit den Fehlermeldungen leider
    überhaupt nichts anfangen. Versteh da nur Bahnhof.
  2. #122
    So, hab jetzt endlich nach langem probieren herausgefunden
    wann mein Fehler kommt.
    Und zwar funktioniert alles bestens bis ich in mein Programm den Befehl " Init(); " eingebe.
    EDIT: Hab eben nochmal ein bischen rumprobiert.
    Und zwar passiert das ganze auch wenn ich einen kleinen Fehler mache, zum Beispiel den
    Strichpunkt am Ende der Zeile vergesse.
    Das kann doch nicht sein das ich wegen so einer kleinen Unachtsamkein alles neu aufbauen muß.
    Danach kommt beim kompilieren immer diese blöde Fehlermeldung bis ich die Lib 2.71 lösche und neu an ihrem Platz kopiere
    das Projekt komplett aus dem Verzeichnis von AsuroFlash lösche,
    AsuroFlash neu starte und ein neues Projekt ohne " Init(); " starte.
    Das Problem ist aber, den Befehl brauch ich doch damit der Prozesor vom Asuro überhaupt weis was er machen soll.
    Oder irre ich mich da?
    Zumindest geht das Programm ohne " Init(); " nicht.
    Vieleicht könnt ihr mir jetzt besser helfen. Bin echt total ratlos und für eure bisherige Hilfe tausendfach dankbar.
    Mfg Tom
  3. #123
    Milda
    die funktion Init() setzt viele notwendige startwerte. wie seiht denn dien restlicher programmcode aus?
    Read... or die.
    ff.mud.de:7600
  4. #124
    Hallo Minifuzi
    m.a.r.v.i.n hat ein makefile Verfasst am: 19.02.2008, 21:21 erstellt,
    hast du dieses in AsuroFlash Cpp Config copiert und dann deinen LIBPAth = C:\ . . . geaendert?.
    Wenn ich mir deine Fehlermeldung anschaue
    solltest du in test.c
    void main(void)
    in
    int main (void)
    aendern.
    wo bei dir ahlms=Test.o steht wird bei mir die AsuroLib eingebunden.
    Vermutlich kennt der Compiler deswegen deine Init(); nicht.
    Das " ; " ist ein kleines Aergernis welches ich auch immer vergesse, ist aber notwendig, weil sonst das Zeilenende nicht erkannt wird.
    Juelicher
  5. #125
    Endlich geschaft!!!!!!!!!!!!!!
    Ich danke euch allen für die Mühe die ihr euch gemacht habt.
    Bisher funktioniert alles. *FREU*
    void main(void)
    in
    int main (void)
    aendern.
    Ich glaub das war der ausschlaggebende Punkt.
    Hab mihc einfach immer auf das standart Template verlassen
    und mir ist nicht aufgefallen das da ein par Fehler drinn sind.
    Mfg Tom
  6. #126
    Hallo Tom,
    das kann ich kaum glauben, dass es daran gelegen haben soll.
    Übrigends kann man das Template auch einfach ändern unter Config | C++ Template TEMPLATE.
  7. #127
    Hallo m.a.r.v.i.n
    jetzt geht es auch schon wieder nicht. Bild
    Genau das gleiche Programm funktioniert aber mit "Programmers Notepad
    ohne Probleme.
    Ich geb jetzt auf, komm gar nicht zum Programieren.
    Mfg Tom
  8. #128
    Heppenheim
    Minifuzi beipflicht...
    Ich hab exakt das selbe Problem... meine Asurolib wird einfach nicht eingebunden, obwohl ich die übers makefile eingebaut habe... Das Tool ist ja schon nett und die Funktionen die das Prog bietet hören sich alle echt gut an, aber es bringt mir leider nichts, weil ich nicht kompilieren kann Bild   Bin gerade auf Arbeit, von daher kann ich die Fehlermeldung die bei mir kommt nichtt posten... werde ich dann zuhause einmal tun...
  9. #129
    Arbeitet ihr beiden vielleicht mit Windoof Vista?
    Sonst fällt mir nicht mehr weiter ein.
  10. #130
    Heppenheim
    negativ... Windoof XP Professional ...
    *edit*
    So bin jetzt zuhause. Im Anhang hab ich mal die Fehlermeldung vom Compiler und mein makefile angehängt. Wäre nett, wenn da mal jemand drüberschauen könnte. Ich hab gestern 2-3h da dran rumgebastelt und geschaut... ich bin dann wieder auf PN umgestiegen...
