Hier mit retten von r24. Jetzt sollte nichts mehr kaputt gehen:
Code:#include <avr/interrupt.h> #include <avr/signal.h> #include <inttypes.h> void foo( uint8_t whichISR ) { volatile uint8_t isr = whichISR; } void _VECTOR(1)( void ) __attribute__ ((naked)); void _VECTOR(1)( void ) { __asm__ __volatile__ ("push r24" ::); foo(1); __asm__ __volatile__ ("pop" ::); __asm__ __volatile__ ("reti" ::); } void _VECTOR(2)( void ) __attribute__ ((naked)); void _VECTOR(2)( void ) { __asm__ __volatile__ ("push r24" ::); foo(2); __asm__ __volatile__ ("pop" ::); __asm__ __volatile__ ("reti" ::); } void _VECTOR(3)( void ) __attribute__ ((naked)); void _VECTOR(3)( void ) { __asm__ __volatile__ ("push r24" ::); foo(3); __asm__ __volatile__ ("pop" ::); __asm__ __volatile__ ("reti" ::); }Code:.file "scratch.c" .arch atmega48 __SREG__ = 0x3f __SP_H__ = 0x3e __SP_L__ = 0x3d __tmp_reg__ = 0 __zero_reg__ = 1 .global __do_copy_data .global __do_clear_bss .section .debug_abbrev,"",@progbits .Ldebug_abbrev0: .section .debug_info,"",@progbits .Ldebug_info0: .section .debug_line,"",@progbits .Ldebug_line0: .text .Ltext0: .global foo .type foo, @function foo: .LFB3: .LM1: /* prologue: frame size=1 */ push r28 push r29 in r28,__SP_L__ in r29,__SP_H__ sbiw r28,1 in __tmp_reg__,__SREG__ cli out __SP_H__,r29 out __SREG__,__tmp_reg__ out __SP_L__,r28 /* prologue end (size=10) */ .LM2: std Y+1,r24 /* epilogue: frame size=1 */ adiw r28,1 in __tmp_reg__,__SREG__ cli out __SP_H__,r29 out __SREG__,__tmp_reg__ out __SP_L__,r28 pop r29 pop r28 ret /* epilogue end (size=9) */ /* function foo size 20 (1) */ .LFE3: .size foo, .-foo .global __vector_1 .type __vector_1, @function __vector_1: .LFB4: .LM3: /* prologue: frame size=0 */ /* prologue: naked */ /* prologue end (size=0) */ .LM4: /* #APP */ push r24 .LM5: /* #NOAPP */ ldi r24,lo8(1) rcall foo .LM6: /* #APP */ pop .LM7: reti /* #NOAPP */ /* epilogue: frame size=0 */ /* epilogue: naked */ /* epilogue end (size=0) */ /* function __vector_1 size 8 (8) */ .LFE4: .size __vector_1, .-__vector_1 .global __vector_2 .type __vector_2, @function __vector_2: .LFB5: .LM8: /* prologue: frame size=0 */ /* prologue: naked */ /* prologue end (size=0) */ .LM9: /* #APP */ push r24 .LM10: /* #NOAPP */ ldi r24,lo8(2) rcall foo .LM11: /* #APP */ pop .LM12: reti /* #NOAPP */ /* epilogue: frame size=0 */ /* epilogue: naked */ /* epilogue end (size=0) */ /* function __vector_2 size 8 (8) */ .LFE5: .size __vector_2, .-__vector_2 .global __vector_3 .type __vector_3, @function __vector_3: .LFB6: .LM13: /* prologue: frame size=0 */ /* prologue: naked */ /* prologue end (size=0) */ .LM14: /* #APP */ push r24 .LM15: /* #NOAPP */ ldi r24,lo8(3) rcall foo .LM16: /* #APP */ pop .LM17: reti /* #NOAPP */ /* epilogue: frame size=0 */ /* epilogue: naked */ /* epilogue end (size=0) */ /* function __vector_3 size 8 (8) */ .LFE6: .size __vector_3, .-__vector_3 .Letext0: .section .debug_line .long .LELT0-.LSLT0 .LSLT0: .word 2 .long .LELTP0-.LASLTP0 .LASLTP0: .byte 0x1 .byte 0x1 .byte 0xf6 .byte 0xf5 .byte 0xa .byte 0x0 .byte 0x1 .byte 0x1 .byte 0x1 .byte 0x1 .byte 0x0 .byte 0x0 .byte 0x0 .byte 0x1 .ascii ".." .byte 0 .ascii "C:/Programme/WinAVR/bin/../lib/gcc/avr/3.4.3/../../../../avr" .ascii "/include" .byte 0 .byte 0x0 .string "stdint.h" .uleb128 0x2 .uleb128 0x0 .uleb128 0x0 .string "scratch.c" .uleb128 0x1 .uleb128 0x0 .uleb128 0x0 .byte 0x0 .LELTP0: .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM1 .byte 0x4 .uleb128 0x2 .byte 0x19 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM2 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM3 .byte 0x19 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM4 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM5 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM6 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM7 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM8 .byte 0x1a .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM9 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM10 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM11 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM12 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM13 .byte 0x1a .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM14 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM15 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM16 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .LM17 .byte 0x15 .byte 0x0 .uleb128 0x3 .byte 0x2 .word .Letext0 .byte 0x0 .uleb128 0x1 .byte 0x1 .LELT0: .section .debug_info .long 220 .word 2 .long .Ldebug_abbrev0 .byte 0x2 .uleb128 0x1 .long .Ldebug_line0 .word .Letext0 .word .Ltext0 .long .LASF10 .byte 0x1 .long .LASF11 .long .LASF12 .uleb128 0x2 .long .LASF0 .byte 0x1 .byte 0x6 .uleb128 0x3 .long .LASF13 .byte 0x1 .byte 0x46 .long 51 .uleb128 0x2 .long .LASF1 .byte 0x1 .byte 0x8 .uleb128 0x4 .string "int" .byte 0x2 .byte 0x5 .uleb128 0x2 .long .LASF2 .byte 0x2 .byte 0x7 .uleb128 0x2 .long .LASF3 .byte 0x4 .byte 0x5 .uleb128 0x2 .long .LASF4 .byte 0x4 .byte 0x7 .uleb128 0x2 .long .LASF5 .byte 0x8 .byte 0x5 .uleb128 0x2 .long .LASF6 .byte 0x8 .byte 0x7 .uleb128 0x5 .long 152 .byte 0x1 .string "foo" .byte 0x2 .byte 0x6 .byte 0x1 .word .LFB3 .word .LFE3 .byte 0x6 .byte 0x6c .byte 0x93 .uleb128 0x1 .byte 0x6d .byte 0x93 .uleb128 0x1 .uleb128 0x6 .long .LASF14 .byte 0x2 .byte 0x5 .long 40 .byte 0x1 .byte 0x68 .uleb128 0x7 .string "isr" .byte 0x2 .byte 0x7 .long 152 .byte 0x2 .byte 0x91 .sleb128 1 .byte 0x0 .uleb128 0x8 .long 40 .uleb128 0x9 .byte 0x1 .long .LASF7 .byte 0x2 .byte 0xc .byte 0x1 .word .LFB4 .word .LFE4 .byte 0x8 .byte 0x90 .uleb128 0x20 .byte 0x93 .uleb128 0x1 .byte 0x90 .uleb128 0x21 .byte 0x93 .uleb128 0x1 .uleb128 0x9 .byte 0x1 .long .LASF8 .byte 0x2 .byte 0x16 .byte 0x1 .word .LFB5 .word .LFE5 .byte 0x8 .byte 0x90 .uleb128 0x20 .byte 0x93 .uleb128 0x1 .byte 0x90 .uleb128 0x21 .byte 0x93 .uleb128 0x1 .uleb128 0x9 .byte 0x1 .long .LASF9 .byte 0x2 .byte 0x20 .byte 0x1 .word .LFB6 .word .LFE6 .byte 0x8 .byte 0x90 .uleb128 0x20 .byte 0x93 .uleb128 0x1 .byte 0x90 .uleb128 0x21 .byte 0x93 .uleb128 0x1 .byte 0x0 .section .debug_abbrev .uleb128 0x1 .uleb128 0x11 .byte 0x1 .uleb128 0x10 .uleb128 0x6 .uleb128 0x12 .uleb128 0x1 .uleb128 0x11 .uleb128 0x1 .uleb128 0x25 .uleb128 0xe .uleb128 0x13 .uleb128 0xb .uleb128 0x3 .uleb128 0xe .uleb128 0x1b .uleb128 0xe .byte 0x0 .byte 0x0 .uleb128 0x2 .uleb128 0x24 .byte 0x0 .uleb128 0x3 .uleb128 0xe .uleb128 0xb .uleb128 0xb .uleb128 0x3e .uleb128 0xb .byte 0x0 .byte 0x0 .uleb128 0x3 .uleb128 0x16 .byte 0x0 .uleb128 0x3 .uleb128 0xe .uleb128 0x3a .uleb128 0xb .uleb128 0x3b .uleb128 0xb .uleb128 0x49 .uleb128 0x13 .byte 0x0 .byte 0x0 .uleb128 0x4 .uleb128 0x24 .byte 0x0 .uleb128 0x3 .uleb128 0x8 .uleb128 0xb .uleb128 0xb .uleb128 0x3e .uleb128 0xb .byte 0x0 .byte 0x0 .uleb128 0x5 .uleb128 0x2e .byte 0x1 .uleb128 0x1 .uleb128 0x13 .uleb128 0x3f .uleb128 0xc .uleb128 0x3 .uleb128 0x8 .uleb128 0x3a .uleb128 0xb .uleb128 0x3b .uleb128 0xb .uleb128 0x27 .uleb128 0xc .uleb128 0x11 .uleb128 0x1 .uleb128 0x12 .uleb128 0x1 .uleb128 0x40 .uleb128 0xa .byte 0x0 .byte 0x0 .uleb128 0x6 .uleb128 0x5 .byte 0x0 .uleb128 0x3 .uleb128 0xe .uleb128 0x3a .uleb128 0xb .uleb128 0x3b .uleb128 0xb .uleb128 0x49 .uleb128 0x13 .uleb128 0x2 .uleb128 0xa .byte 0x0 .byte 0x0 .uleb128 0x7 .uleb128 0x34 .byte 0x0 .uleb128 0x3 .uleb128 0x8 .uleb128 0x3a .uleb128 0xb .uleb128 0x3b .uleb128 0xb .uleb128 0x49 .uleb128 0x13 .uleb128 0x2 .uleb128 0xa .byte 0x0 .byte 0x0 .uleb128 0x8 .uleb128 0x35 .byte 0x0 .uleb128 0x49 .uleb128 0x13 .byte 0x0 .byte 0x0 .uleb128 0x9 .uleb128 0x2e .byte 0x0 .uleb128 0x3f .uleb128 0xc .uleb128 0x3 .uleb128 0xe .uleb128 0x3a .uleb128 0xb .uleb128 0x3b .uleb128 0xb .uleb128 0x27 .uleb128 0xc .uleb128 0x11 .uleb128 0x1 .uleb128 0x12 .uleb128 0x1 .uleb128 0x40 .uleb128 0xa .byte 0x0 .byte 0x0 .byte 0x0 .section .debug_pubnames,"",@progbits .long 67 .word 2 .long .Ldebug_info0 .long 224 .long 100 .string "foo" .long 157 .string "__vector_1" .long 179 .string "__vector_2" .long 201 .string "__vector_3" .long 0 .section .debug_aranges,"",@progbits .long 16 .word 2 .long .Ldebug_info0 .byte 0x2 .byte 0x0 .word .Ltext0 .word .Letext0-.Ltext0 .word 0 .word 0 .section .debug_str,"MS",@progbits,1 .LASF5: .string "long long int" .LASF12: .string "D:\\priv\\Tech\\atmel\\learning\\scratch\\default" .LASF2: .string "unsigned int" .LASF10: .string "GNU C 3.4.3" .LASF4: .string "long unsigned int" .LASF6: .string "long long unsigned int" .LASF14: .string "whichISR" .LASF13: .string "uint8_t" .LASF1: .string "unsigned char" .LASF3: .string "long int" .LASF7: .string "__vector_1" .LASF8: .string "__vector_2" .LASF9: .string "__vector_3" .LASF0: .string "signed char" .LASF11: .string "../scratch.c" /* File "../scratch.c": code 44 = 0x002c ( 25), prologues 10, epilogues 9 */
Zitieren
