Ergebnis 1 bis 10 von 10
Thema: SD20 über I2C an C-Control1 auf A.Board funktioniert nicht
Baum-Darstellung
  1. #10
    Earth
    Hello,
    I’m sorry to hear that you C-Control is malfunctioning.
    I have created a small test program for you to try.
    You will need to use a terminal program because the program will ask you for a servo number and a servo position.
    Make sure to use 2 power supply’s, 1 power supply for the C-Control and SD20(+5V from C-Control), the other power supply for your servo.
    Remember to connect all the power supply GND’s (-) together.
    Greetings,
    H.J. Windt
