Ok, aachtung, hier kommt er:
E ist ein ByteCode:$regfile = "m8def.dat" $crystal = 6000000 $hwstack 128 $swstack 128 Dim X(400) As Byte Dim Y(300) As Byte Dim H(27) As String * 1 'Array für Codiertes Byte und Präambel Dim I As Byte 'For-Schleifen-Zählvariable Dim R As Byte 'For-Schleifen-Zählvariable Dim B As Byte ' Dim T As Byte Dim L As Word Dim O As Word Dim Q(40) As Byte Dim U As Byte U = 0 Dim J As Byte J = 1 Dim W As Byte W = 1 Dim E As Byte Dim M As String * 2 Dim P As String * 1 Dim C As Byte C = 0 Dim Da As Byte Da = 0 Dim Z As Byte Z = 0 Dim K As Byte Ddrb.1 = 1 'FET-Ausgang Ddrb.2 = 0 'Sende-Taster-Eingang Portb.2 = 1 Ddrb.3 = 0 Portb.3 = 1 'Up-Taster Ddrb.4 = 0 Portb.4 = 1 'Down-Taster Ddrb.5 = 0 Portb.5 = 1 'Enter-Taster H(1) = " " H(2) = "A" H(3) = "B" H(4) = "C" H(5) = "D" H(6) = "E" H(7) = "F" H(8) = "G" H(9) = "H" H(10) = "I" H(11) = "J" H(12) = "K" H(13) = "L" H(14) = "M" H(15) = "N" H(16) = "O" H(17) = "P" H(18) = "Q" H(19) = "R" H(20) = "S" H(21) = "T" H(22) = "U" H(23) = "V" H(24) = "W" H(25) = "X" H(26) = "Y" H(27) = "Z" X(1) = 0 X(2) = 1 X(3) = 0 X(4) = 1 X(5) = 0 X(6) = 1 X(7) = 0 X(8) = 1 Config Lcd = 20 * 2 Config Lcdpin = Pin , E = Portb.0 , Rs = Portd.4 , Db7 = Portd.3 , Db6 = Portd.2 , Db5 = Portd.1 , Db4 = Portd.0 Cursor On Cls Config Timer1 = Timer , Prescale = 1 Enable Interrupts Enable Timer1 On Timer1 Senden Stop Timer1 L = 59000 'Zuerst die Präambel mit Zeitabstand x O = 65534 - L O = O / 2 O = 65534 - O T = 1 Locate 1 , 1 Lcd "Bitte Text eingeben" Locate 2 , 1 Do If Pinb.2 = 0 Then ' Senden-Taste Waitms 200 Cls Da = 0 For I = 1 To U E = Q(i) For R = 1 To 8 M = Bin(e) P = Mid(m , R , 1) C = Val(o) Incr Da Y(da) = C Next R Next I ' Jetzt wird dieses Byte per Manchester-Verfahren codiert: ' 1=01 ' 0=10 B = 9 K = 8 * U For I = 1 To K Step 1 If Y(i) = 1 Then X(b) = 0 Incr B X(b) = 1 Elseif Y(i) = 0 Then X(b) = 1 Incr B X(b) = 0 End If Incr B Next I ' Nun haben wir im Array x(1-24) das Manchester-Codierte Byte und die (nicht codierte) Präambel. ' Jetzt muss dieses Byte gesendet werden. ' Dazu verwenden wir Timer1 Timer1 = L Start Timer1 End If If T = 9 Then L = O 'Dann das Byte mit Flankenwechsel nach Zeitabstand x/2 Timer1 = L Portb.1 = X(t) Incr T End If Z = U * 16 Z = U + 9 If T = Z Then Stop Timer1 T = 1 L = 59000 U = 0 J = 1 W = 1 Portb.1 = 0 Locate 1 , 1 Lcd "gesendet" Wait 3 Locate 1 , 1 Lcd "Bitte Text eingeben" Locate 2 , 1 Lcd " " End If If Pinb.3 = 0 Then ' Up-Taste Waitms 200 Incr J If J = 28 Then J = 1 End If Locate 2 , W Lcd H(j) End If If Pinb.4 = 0 Then ' Down-Taste Waitms 200 Decr J If J = 0 Then J = 27 End If Locate 2 , W Lcd H(j) End If If Pinb.5 = 0 Then Incr W 'Enter-Taste Waitms 200 Incr U Q(u) = J Locate 2 , W J = 1 Lcd H(j) End If Loop Senden: Timer1 = L Portb.1 = X(t) Incr T Return End
M ist ein String *2
P ist ein String *1
da ist ein Byte
Irgendwie sollte er ja trotzdem nicht einfach so Werte zuordnen...
Zitieren
