Im Gegensatz zu beep() erzeugt sound() eine zusätzliche Pause nach dem Ton. Die Funktion in RP6ControlLib.h:
#define sound(_pitch_,_time_,_delay_) {beep(_pitch_,_time_);mSleep(_delay_ + _time_);}
Das bedeutet, sound(tonhöhe, dauer, pause) macht das: beep(tonhöhe, dauer); mSleep(pause);
Beschrieben wird das in RP6ControlLib.c beim beep():
* You can use this function to make the beeper beep ;)
* But this function should not be used as it does not
* generate a delay for the sound and a delay between
* two sounds. Better is to use the "sound" macro, which
* uses this function and adds the required delays.
* "sound(pitch,time,delay)"
* 0 = lowest frequency
* 255 = highest frequency
* Example:
* sound(150,50,25);
* sound(200,50,25);
* Of course the function "beep" is nice to generate
* sounds when you need to do other things at the same
* time...
void beep(uint8_t pitch, uint16_t time)
controlStatus.beep = true;
sound_timer = time;
OCR2 = 255-pitch;
TCCR2 = (1 << WGM21) | (1 << COM20) | (1 << CS22) | (1 << CS21);
Mehr Infos zu beep():
https://www.roboternetz.de/community...z-beim-Beeper?
