Dieser Code funktioniert, der PIC arbeitet mit 31250 Hz:
Dieser Code funktioniert nicht, der PIC rührt sich nicht, obwohl die Bedingungen erfüllt wurden:Code:OSCCONbits.SCS1 = 1; OSCCONbits.IRCF0 = 0; OSCCONbits.IRCF1 = 0; OSCCONbits.IRCF2 = 0; OSCTUNEbits.INTSRC = 1; //INTSRC: Internal Oscillator Low-Frequency Source Select bit //1: 31.25 kHz device clock derived from 16 MHz HFINTOSC source (divide-by-512) //0: 31.00 kHz device clock derived directly from LFINTOSC internal oscillator
Hier noch meine Config:Code:OSCCONbits.SCS1 = 1; OSCCONbits.IRCF0 = 0; OSCCONbits.IRCF1 = 0; OSCCONbits.IRCF2 = 0; OSCTUNEbits.INTSRC = 0; //INTSRC: Internal Oscillator Low-Frequency Source Select bit //1: 31.25 kHz device clock derived from 16 MHz HFINTOSC source (divide-by-512) //0: 31.00 kHz device clock derived directly from LFINTOSC internal oscillator
Danke für die Hilfe.Code:#pragma config FOSC = IRC //POR => Internal RC oscillator. #pragma config PLLEN = OFF //PLL is ENABLED. #pragma config CPUDIV = NOCLKDIV //No CPU System Clock divide. #pragma config HFOFST = OFF //Warten bis System-clock stabil. #pragma config PCLKEN = OFF //Primary clock is under software control. #pragma config FCMEN = OFF //Fail-Safe Clock Monitor disabled. #pragma config PWRTEN = ON //Power-UP-Timer enabled. #pragma config MCLRE = ON //MCLR pin enabled, RA3 input pin disabled. #pragma config BOREN = ON //Brown-out Reset enabled. #pragma config BORV = 30 //VBOR set to 3.0V /* #pragma config BORV = 27 //VBOR set to 2.7V #pragma config BORV = 22 //VBOR set to 2.2V #pragma config BORV = 19 //VBOR set to 1.9V */ #pragma config IESO = OFF //Oscillator Switchover mode disabled. #pragma config LVP = OFF //Low Voltage ICSP. #pragma config STVREN = OFF //Stack full/underflow will not cause Reset. #pragma config WDTEN = OFF //Watchdog Timer OFF. #pragma config BBSIZ = OFF //1kW boot block size. #pragma config EBTR0 = OFF //Block 0 not prot. from table reads exec. in other blocks. #pragma config EBTR1 = OFF //Block 1 not prot. from table reads exec. in other blocks. #pragma config EBTRB = OFF //Boot block not prot. from table reads exec. in other blocks. #pragma config WRT0 = OFF //Block 0 not write-protected. #pragma config WRT1 = OFF //Block 1 not write-protected. #pragma config WRTB = OFF //Boot block not write-protected. #pragma config WRTC = OFF //Configuration registers not write-protected. #pragma config WRTD = OFF //Data EEPROM not write-protected. //CPn-Bit's schützen vor externen Read/Write angriffen. #pragma config CP0 = OFF //OFF: Block 0 not code-protected. #pragma config CP1 = OFF //OFF: Block 1 not code-protected. #pragma config CPB = OFF //OFF: Boot block not code-protected. #pragma config CPD = OFF //OFF: Data EEPROM not code-protected. #pragma config XINST = OFF //Instruction set extension & Indexed Addr. mode disabled.
Zitieren
