hallo, wer kann helfen diese mmc-lib direkt in asm umzuwandeln damit diese als normale asm in Bascom eingebunden wird?
Copyright = Mcs Electronics/Vgel Franz Josef
Www = Http://Www.mcselec.com / http://members.aon.at/voegel
Email = Avr@mcselec.com
Comment = Mmc Driver For Avr-dos Compiler Library
Libversion = 2.00
Date = 25 April 2005
Statement = No Source Code From The Library May Be Distributed In Any Form Unless You Have Permision From The Author
Statement = For support please check http://members.aon.at/voegel for contact address
History = No Known Bugs.
; Error conditions:
; 225: Error response Byte at Reset command
; 226: Error response Byte at Init Command
; 227: Error response Byte at Read Command
; 228: Error response Byte at Write Command
; 229: No Data response Byte from MMC at Read
; 230: No Data response Byte from MMC at Write
*BASIC: Reset Mmc_cs                                     ' reset Cs
   rcall _Byte2SPI                                ; Send CMD
   mov r16,r23                                    ; send MSB first
   rcall _Byte2SPI
   mov r16,r22
   rcall _Byte2SPI
   mov r16,r21
   rcall _byte2spi
   mov r16,r20                                    ; LSB last
   rcall _byte2spi
; now falls into get response
; Wait for non &HFF response
; Not getting Byte: T-Flag set
  push r17
  push r18
  ;ldi r17, 64                     ; ask 64 times for response
  clr r17
  clr r18
  clt                             ; clear low level error flag
  rcall _Byte2SPI_255
  cpi r16, &HFF
  brne _MMC_GetResponse2
  subi r17, 1
  sbci r18, 0
  brne _MMC_GetResponse1
  pop r18
  pop r17
  tst r16                        ; set Z-Flag if Response = 0, do not affect C-Flag
*BASIC: Set Mmc_cs                                       ' Set CS HIGH
   ldi r17,10                                       ; Clock Counter, 80 pulses with CS high
   rcall _Byte2SPI_255
   dec r17                                          ; send 80 clock pulses
   Brne _MMC_Reset_0
*BASIC: Reset Mmc_cs                                     ' Reset Cs to LOW
   ldi r16,64                                       ; Send CMD0
   rcall _Byte2SPI
   rcall _Byte2SPI_0
   rcall _Byte2SPI_0
   rcall _Byte2SPI_0
   rcall _Byte2SPI_0
   ldi r16,149                                     ; first command needs proper CRC Byte
   rcall _Byte2SPI
   ldi r17, 100                                     ; try 100 times to get proper response
   rcall _MMC_GetResponse
   cpi r16, 1                                      ; 1 is proper response after reset
   breq _MMC_Reset2
   dec r17
   brne _MMC_Reset1
 * Ldi R25 , Cperrdrivereset
   rjmp _MMC_Exit_Error
   rjmp _MMC_Exit_Standard
; Init the MMC-Card
   ldi r17,10                                     ; try 10 times to init
*BASIC: Reset Mmc_cs                                     ' Reset CS
   ldi r16,65   ; CMD1
   rcall   _Byte2SPI
   rcall   _Byte2SPI_0
   rcall   _Byte2SPI_0
   rcall   _Byte2SPI_0
   rcall   _Byte2SPI_0
   breq _MMC_Init3                                 ; response Byte is zero?
   rcall _MMC_Exit_Standard                        ; deactivate MMC_CS for new try
*BASIC: Waitms 50
   dec r17
   brne _MMC_Init1
 * Ldi R25 , Cperrdriveinit
*#IF cMMC_Soft = 1
   ser r16
   rjmp _Byte2SPI
   clr r16
   push r19                               ; scratch register
   push r18                               ; bit loop counter
   push r17                               ; income Byte
   clr r17
   ldi r18, 8                             ; 8 Bits to receive
   lsl r17
   lsl r16                                ; byte to send
   brcs _Byte2SPI_1
 * cbi MMC_PortMOSI, bMMC_MOSI
   rjmp _Byte2SPI_Clock
 * sbi MMC_PortMOSI, bMMC_MOSI
 * in r19, MMC_PortMISO
 * sbi MMC_PortSCK, bMMC_SCK
 * cbi MMC_PortSCK, bMMC_SCK
;   nop                                   ; following code have enough delay
;   nop
;   nop
 * sbrc r19, bMMC_MISO
   inc r17
   dec r18
   brne _Byte2SPI_Loop
   mov r16, r17                           ; return value
   pop r17
   pop r18
   pop r19
   ser r16                              ; send 255
   rjmp _Byte2SPI
   Clr r16                              ; send 0
 * Out Spdr , R16
 * Sbis Spsr , 7 ; Wait For Spif
   rjmp _byte2spi2
 * In R16 , Spdr
   clr r20
   ld r21,x+   ;LSB
   ld r22,x+
   ld r23,x+
   lsl r21
   rol r22
   rol r23
; Read Sector(s) from MMC-Card to SRAM
; Entry with following parameters set:
; Register X: Pointer to Sectornumber (LONG)
; Register Z: SRAM-Address, where the data to transfer
   rcall _DriveClearErrorBytes
   rcall _Shift_MMC
   ldi r16,$51
   rcall _MMC_Send_Command
   breq _MMC_ReadSector1                  ; response = 0?
 * Ldi R25 , Cperrdrivereadcommand
   cpi r16, &HFE                          ; get data response byte
   breq _MMC_ReadSector2
 * Ldi R25 , Cperrdrivereadresponse
   ldi r25,2                              ; 512 bytes to read
   clr r24
   rcall _byte2spi_255
   st z+,r16
   sbiw r24,1
   brne _MMC_ReadSector3
   rcall _byte2spi_255                    ; read first crc byte
   rcall _byte2spi_255                    ; read second crc byte
; write Sector(s) to MMC-Card
; Entry with following parameter set:
; Register Z: SRAM-Address, at which Data to transfer starts
   rcall _Shift_MMC
   ldi r16,88                          ; write
   breq _MMC_WriteSector1              ; Response = 0?
 * Ldi R25 , Cperrdrivewritecommand
   rcall _byte2spi_255
   ldi r16,254
   rcall _byte2spi
   ldi r25,2                           ; counter for 512 bytes
   clr r24
   ld r16,z+
   rcall _byte2spi
   Sbiw r24,1
   brne _MMC_WriteSector2
                                       ; dummy crc bytes
   rcall _byte2spi_255
   rcall _byte2spi_255
   rcall _Byte2SPI_255                 ; read Data response byte (=xxx00101b)
   andi r16, &H1F
   sts {gbDriveDebug}, r16             ; save Data response byte for debug
   clr r17
   ldi r18, 255                         ; 10000 * 10Sec = 100mSec wait for writing down
   rcall _DriveWaitUS10
   rcall _Byte2SPI_255
   tst r16                             ; end of busy
   brne _MMC_WriteSector5
   subi r17, 1
   sbci r18, 0
   brne _MMC_WriteSector4              ; Wait ~ 65536 * 25 Cycles for end of busy
                                       ; ~ 100mSec at 16MHz Crystal, should be long enough
 * Ldi R25 , Cperrdrivewriteresponse
; Setup the pins needed for the CF-Card
*#IF cMMC_Soft = 0
*BASIC: Spiinit
   rcall _MMC_Reset
   brcc _DriveInit1
   rjmp _MMC_Init0
; force MMC-Card to a Hardware-reset
   rjmp _MMC_Reset
; Checks, whether Card is plugged in: not yet supported with this driver
; if OK r24 = 1; otherwise 0
   ldi r24, 1
   rjmp _MMC_Exit_Standard1
 * Ldi R25 , Cperrdrivenotsupported
   rjmp _driveSetError
; clear all drive according error bytes
   clr r25
 * Sts {gbdriveerror} , R25
 * Sts {gbdrivestatusreg} , R25
 * Sts {gbdriveerrorreg} , R25
*BASIC: Set Mmc_cs
   rcall _Byte2SPI_255                          ; send 255
   clr r25                                      ; clear error byte
   clc                                          ; clear error flag
   rcall _DriveSetError
*BASIC: Set Mmc_cs
   rcall _Byte2SPI_255
   sec                                          ; set error flag
; Entry with Error-Code in r25
; Last response from mmc in r16
 * Sts {gbdrivestatusreg} , R16
   sec                                        ; Error flag for AVR-DOS
* ldi r25, ( ( _XTAL * 10 ) / 3000000 )                 ; 1 loop needs 3 cycles
  dec r25
  brne _DriveWaitUS10a
